Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
Among Us is a social deduction game developed by InnerSloth that gained immense popularity in 2020.
Get high-quality work done as per the requirements with the reference to genuine sources for achieving higher grades. We are experts in meeting academics deadlines. So, feel free to contact us and become tension free   Online dissertation writer uk
Morne-hurez's picture
Setting up your development environment for android game development is essential for smooth progress. Utilize user-friendly tools like Android Studio and Unity to simplify your workflow. By configuring these platforms properly, you'll ensure seamless coding, testing, and optimization, paving the way for successful game creation.
This guide shows how to set up a Django development environment on Ubuntu 16.04 and subsequent LTS editions. It involves installing Python 3, pip 3, Django, and virtualenv to offer you all the tools you need to create web applications with Django. basketball stars
As a student aspiring to become a game developer, I focus on honing my skills through practice and learning. While seeking assistance, I've found that relying on the best assignment writing service ensures high-quality support tailored to my needs. This allows me to excel in both my coursework and my passion for game development.
Hey folks! Setting up your dev environment on Ubuntu 16.04 or later? Easy peasy! Just update your system, install necessary packages like build-essential, openocd, git, libudev-dev, and qt-sdk. Don't forget gcc-arm-embedded toolchain - add the repo, update, and install. Lastly, grab those udev rules for STLink V2. Voila! All set! Check out more tips like this on SavvyTipsGuru, perfect for business and course and jobs. Happy coding!
Hey there, community!
Are you on the lookout for skilled WooCommerce developers for hire to level up your e-commerce game? Look no further! Whether you're starting a new online store or revamping an existing one, finding the right developers is key to success.
If you need talented WooCommerce experts, you're in luck. This forum is teeming with seasoned professionals ready to tackle your projects with precision and finesse. Share your requirements, discuss your vision, and let's connect you with the perfect developers to bring your e-commerce dreams to life.
Don't hesitate to reach out and start the conversation! 🛒💻
The Custom Airline Software Development Guide by Attract Group is a comprehensive resource for aviation companies looking to elevate their operations. It delves expertly into the nuances of developing tailored software solutions, ensuring airlines can optimize processes, enhance customer experience, and stay competitive in a dynamic industry. Highly informative for stakeholders!
I really like the word game waffle. Not the same as the daily one. You can play the "unlimited" version of Waffle until you get tired of it. The figures in the box tell you what to do. Move the characters around so that all of the rows, both vertical and horizontal, line up with each other to make words. You can move 15 times. The game will end after 15 tries if it can't move the characters to the right place.
adrianadarby01's picture
Global Assignment Help is a leading platform offering comprehensive academic assistance to students worldwide. With a team of experienced professionals and subject matter experts, they provide top-notch assignment writing, editing, and proofreading services across various disciplines. Their commitment to quality, timely delivery, and customer satisfaction sets them apart. Whether it's essays, research papers, case studies, or dissertations, Global Assignment Help ensures thorough research, original content, and adherence to academic standards.
AdrianaDarby
