2. Motor Setup Wizard
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Vesc-Tool_MSM_intro
Vesc-Tool_MSW_wiring
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Vesc-Tool_MSW_connect
Vesc-Tool_MSW_start
Vesc-Tool_MSW_default
VESC-Tool MSW_choose FOC
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
Vesc-Tool_FW_current limits warning
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current.  Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Vesc-Tool_MSW_current limits set
Vesc-Tool_MSW_battery cutoff_warning
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
VESC-Tool MSW_battery cutoff_set values
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the  the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Vesc-Tool_MSW_select sensors
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Vesc-Tool_MSW_motor parameter_01
Vesc-Tool_MSW_motor parameter_02
Vesc-Tool_MSW_motor parameter_03
Vesc-Tool_MSW_motor parameter_04
Vesc-Tool_MSW_motor parameter_05
Vesc-Tool_MSW_sensor calibration_01
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Vesc-Tool_MSW_sensor calibration_02
Vesc-Tool_MSW_sensor calibration_03
Vesc-Tool_MSW_finish
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
A spacebar counter is a tool or software that counts the number of times the spacebar on a keyboard is pressed. It is typically used for various purposes, such as measuring typing speed, monitoring user activity, or tracking the number of spaces in a document or text. Spacebar counters can be integrated into standalone software applications, browser extensions, or other software programs. Some spacebar counters may also provide additional features such as recording keystrokes, calculating typing accuracy, or generating statistics and reports.
Great information! I will visit your site more often so I am updated. The ideas I gather from here cannot be paid with money. Thanks very much!
tunnel rush
Also thanks to this specific configuration guide that I was able to handle and it worked, I am happy to be a member of the Forum and I can wordle today consult and communicate with other members related to VESC ! Once again thank you!
This article is interesting and creates curiosity from the start with a catchy title. I was hooked from the very beginning slope and couldn't take my eyes off its remarkable content.  retro bowl
dino game is a fun and simple game that you can play on your browser when you have no internet connection. It features a cute T-Rex dinosaur that runs across an endless desert and tries to avoid obstacles like cacti and pterodactyls. You can control the dinosaur by jumping or ducking with the spacebar or the arrow keys on your keyboard, or by tapping on your mobile screen. The game gets faster and harder as you progress, and the background color changes from day to night. The game was created by Google Chrome developers as an easter egg in 2014, and it has become very popular among users, with over 270 million players every month. The game is also known as Chrome Dino, dinosaur game, T-Rex Game, Dino Run, or No Internet Game. You can play the game online for free on various websites, or by typing "chrome://dino" in your browser address bar. The game has a maximum score of 99999, after which it resets to zero
Here is a possible paragraph that summarizes what I know about the Dino game:
The Dino game is an entertaining way to pass the time when you are offline. You can play as a T-Rex dinosaur that runs and jumps over obstacles in a desert. The game was made by Google Chrome developers in 2014 and has millions of fans around the world. You can access the game online or by typing "chrome://dino" in your browser. The game has a limit of 99999 points, which is a challenge for many players.
The way you present information is really professional slope and clear, making it easy for readers to absorb without feeling tired.
I can tell you put a lot of time and fnaf effort into crafting this post. It shows in the quality of your writing and the depth of your analysis.
I really hope there will be a lot more content like this. I am grateful that you shared your information with me. Your blog has been bookmarked because I discovered some extremely useful information on it. capybara clicker
Thank you for providing such useful information. I've been having trouble slope coming up with many questions about this topic. I'll stick with you!
Slitherio is a game that celebrates the power of teamwork and cooperation - whether you're working together to achieve a common goal or supporting each other through tough times, there's always strength in unity and solidarity in the world of Slither
Quordle is an interesting game that challenges the player's intelligence and creativity. It has quickly become a new phenomenon in the community of word guessing game enthusiasts.
Smokers World HW Disposable Vape Bundles offer a convenient and enjoyable vaping experience for enthusiasts. These Products come in a variety of flavors, providing users with a range of options to suit their preferences. Each bundle includes a selection of high-quality, pre-filled devices that are easy to use and require no maintenance. With a sleek and compact design, these disposable vapes are perfect for on-the-go use, fitting comfortably in pockets or purses. The hassle-free nature of the product makes it an ideal choice for those looking for a hassle-free vaping experience. Explore the diverse flavors and enjoy the simplicity of vaping with Smokers World HW Disposable Vape Bundles
STEP 2 - Using The Motor Setup Wizard will probably be the easiest option. Select the Motor Setup Wizard as shown in the image below. word search
Your instructions for installing this engine are wordle very specific and detailed. I rarely see an article that shares it as completely as this one. Most of the articles I have read only provide instructions or share instructions. share in certain highlights and this article is completely different, thank you for sharing it with everyone.
Zeus138 adalah salah satu platform permainan slot daring yang terkenal dan sangat terpercaya di kalangan pemain judi online. Website ini terkenal karena menyajikan berbagai jenis permainan slot yang menarik dan selalu mudah untuk dimenangkan. Dengan desain yang mudah digunakan dan antarmuka yang mudah dipahami, Zeus 138 menyediakan pengalaman bermain yang tanpa hambatan bagi penggunanya.
You truly are exceptional since you have a remarkable ability for motivating others with only a few words.
retro bowl
Interesting articles keep posting more!
buildnow gg
Disposable Dummy Vapes Products bundles typically come with a fully charged battery. This means you can start vaping immediately without the need to worry about charging cables or finding power outlets.
I thoroughly enjoyed your article. For me, this is an excellent piece of paper. I bookmarked it and will return to read any fresh content. dordle game
GregorySmith's picture
As a student navigating tight deadlines and complex presentation requirements, trusting a power point writer https://paperwriter.com/presentation-writer  becomes more than a convenience; it's a lifeline. With paper writer, the stress dissipates. Their team of skilled professionals ensures not just a presentation, but a masterpiece tailored to impress, all at a reasonable cost.
Your blog is a treasure trove of valuable information. Keep up the excellent work! Solar
This article has been really useful. I value your generosity in making it available to me and the public at large. fnaf unblocked
You are very extraordinary since you have an amazing capacity to motivate people with only a few words. coreball
Your articles have helped me to learn a lot of interesting information on this topic and they are important material from which I can come up with many good ideas.
fnf
I believe that with the information you share, it will bring a lot of value to the readers
slope and I hope that they will absorb the good and useful things.
Setting up your VESC® or VESC® based ESC for your BLDC motor sounds like a fun project! Using the VESC®-Tool Software makes it a breeze, especially with the Motor Setup Wizard. Going for FOC mode and utilizing Hall sensors is a smart move for smooth operation. Just follow along step by step, and you'll have everything configured in no time. And hey, if you need any extra help, don't worry—I've got your back. Also, I gotta say, the VESC®-Tool Software offers the easiest PDF conversion in today’s market, so you can easily save or share your configurations hassle-free!
answersrepublic.com/health/best-smartwatch-for-diabetics/
A monkeytype is an assessment or exercise designed to measure a person's typing speed, accuracy, and overall proficiency in using a keyboard to type written content. The goal is to evaluate how fast and accurately an individual can type a given set of words, sentences, or paragraphs within a specified time limit.
I have read your instructions very carefully and am following each step as you are instructing here, the instructions have some images that are not working so I don't know how to make it work at all, can you update Update the image above or not? If possible please fix it soon and I would be a wordle today lot happy if you do, thank you very much.
