VESC Tool manuals (non video based)
Submitted by frank on Tue, 2017-10-03 19:42
Comments
What kind of Operating System on my computer do i need to use the VESC Tool?
Greetings
Schlawiner
I am currently setting up my ESC using motor setup wizard, however, when asked to run the detection for the parameters, my motor does not cooperate. I have gone through both FOC and BLDC, however neither are working. Any advice for how to make it work. I am using a torque board motor 6353/190KV and my battery that I am trying to set it up with is 4 cells 5.2 A, 14.8V. I plan on running my longboard with two of these LiPo batteries
Hi mjmarchetto
maybe you got it working in the meantime, but I guess you are facting the same problem as I that your setup has a high inertio, so the overcurrent protection got in between. Try to set the eRPM (500afaik) in the detection lower for FOC. For BC (called BLDC here) I did not get mine working at all; as I got not feedback how to tweak the setup I was unable to get further on that front, but as FOC works as it should (so far) it's OK for me.
Cheers
Sam
supertiny808's picture
Hi , It is worth re-checking the integrity of all electrical Power and sensors. Tighten any connections or secure where possible, effectively you have to look at all your wires and see which one is duff, enjoy :)
808
Hi, You can use whats called a "Virtual Machine" to run linux, mac, or windows OS's on your computer. I have a PC, and I run Linux through a virtual machine. My friend has a mac, and he runs Windows 10 on his mac on a VM. The software is called virtual box. Its made by a pretty big company named Oracle. It is free! Get ready to watch some youtube videos on the subject if you're unfamiliar with it.  https://www.virtualbox.org/
Hi, i seem to be having trouble simply connecting to my dual FOCBox setup.... it says something about delay semaphore expired could it have something to do with baud rate?
Zoom zoom
I am trying to install bldc tool on windows 10 but instalation crashes on startup is there any trick to fix this issue?
Been googling around for VESC tool errors and I'm not coming up with much. There might be some specific compatability issues here. What kind of error code were you getting btw (if you still have it, I realize this was 6 months ago.)  I'm gettting a 0xc5
Unfortunately I can't even start the tool on windows,
I copied exe file to desktop and when I double click it, it shows an error message."vesc 2.02 exe stopped working" Windows will close the program.
Any ideas?
Mac Motor
I have installed the tool properly and when I click to open it begins to open and immediately closes and disappears, I removed all security settings leaving my computer wide-open but still it doesn't work and I see other people have the same problem so it would be real nice if somebody would respond with a fix.
it would be nice if somebody replied with a fix in July 2020
ernest sanne
which types of motors are supportred by the VESC controller
can we use it with all AC and DC motors?
can we use it with PMSM?
or only BLDC?
Thanks,
Mohamed
добавляю vesc tool в корзину, нажимаю кнопку (оформить заказ) из корзины всё пропадает, и сообщает что (vesc tool из корзины удалён ) соответсвенно покупки не происходит! подскажите как быть?
Сергей
Hi good afternoon.
I have a request for you, I have already registered on your vesc tool page.
However, I do not get an e-mail with the program that I can program my mountainboard vesc.
In this regard, I would ask you if you would send me the program by email.
Kind regards
Gardener Gabriel.
Name .Gardener Gabriel
e-mail. ggleba@yahoo.de
After days of trying to get into vesc I just saw summing about using windows to do this you wood think that wood be the first thing on this web site I just want to start my EBike with my calibike Bluetooth dongle can't believe what you have done with something that was so simple to get into bin trying to get into my yuyangking app for days now I can believe this I make sum of the fastest EBikes and I can't get this older bike that I made to even start with what you have done
/storage/emulated/0/Download/calibike_mobile_1.01.apk_ (6)/calibike_mobile_1.01.apk
