I am currently setting up my ESC using motor setup wizard, however, when asked to run the detection for the parameters, my motor does not cooperate. I have gone through both FOC and BLDC, however neither are working. Any advice for how to make it work. I am using a torque board motor 6353/190KV and my battery that I am trying to set it up with is 4 cells 5.2 A, 14.8V. I plan on running my longboard with two of these LiPo batteries
maybe you got it working in the meantime, but I guess you are facting the same problem as I that your setup has a high inertio, so the overcurrent protection got in between. Try to set the eRPM (500afaik) in the detection lower for FOC. For BC (called BLDC here) I did not get mine working at all; as I got not feedback how to tweak the setup I was unable to get further on that front, but as FOC works as it should (so far) it's OK for me.
Hi , It is worth re-checking the integrity of all electrical Power and sensors. Tighten any connections or secure where possible, effectively you have to look at all your wires and see which one is duff, enjoy :)
Hi, You can use whats called a "Virtual Machine" to run linux, mac, or windows OS's on your computer. I have a PC, and I run Linux through a virtual machine. My friend has a mac, and he runs Windows 10 on his mac on a VM. The software is called virtual box. Its made by a pretty big company named Oracle. It is free! Get ready to watch some youtube videos on the subject if you're unfamiliar with it. https://www.virtualbox.org/
Hi, i seem to be having trouble simply connecting to my dual FOCBox setup.... it says something about delay semaphore expired could it have something to do with baud rate?
Been googling around for VESC tool errors and I'm not coming up with much. There might be some specific compatability issues here. What kind of error code were you getting btw (if you still have it, I realize this was 6 months ago.) I'm gettting a 0xc5
I have installed the tool properly and when I click to open it begins to open and immediately closes and disappears, I removed all security settings leaving my computer wide-open but still it doesn't work and I see other people have the same problem so it would be real nice if somebody would respond with a fix.
it would be nice if somebody replied with a fix in July 2020
добавляю vesc tool в корзину, нажимаю кнопку (оформить заказ) из корзины всё пропадает, и сообщает что (vesc tool из корзины удалён ) соответсвенно покупки не происходит! подскажите как быть?
Hi good afternoon.
I have a request for you, I have already registered on your vesc tool page.
However, I do not get an e-mail with the program that I can program my mountainboard vesc.
In this regard, I would ask you if you would send me the program by email.
Kind regards
Gardener Gabriel.
Name .Gardener Gabriel
e-mail. ggleba@yahoo.de
After days of trying to get into vesc I just saw summing about using windows to do this you wood think that wood be the first thing on this web site I just want to start my EBike with my calibike Bluetooth dongle can't believe what you have done with something that was so simple to get into bin trying to get into my yuyangking app for days now I can believe this I make sum of the fastest EBikes and I can't get this older bike that I made to even start with what you have done
Comments
VESC Tool
What kind of Operating System on my computer do i need to use the VESC Tool?
Greetings
Schlawiner
Operating System
Windows 7 or later, LINUX.
Frank
Detection Failure
Hi mjmarchetto
Hi mjmarchetto
Cheers
Sam
Electrical
hope you develop VESC Application to work on the iOS or OSX
I only own Apple Hardware... I may have to buy a Windows or Linux emulator program or another computer to access VESC tools.. thx
vesc-tool 1.08 connection
Installation crashes
I am trying to install bldc tool on windows 10 but instalation crashes on startup is there any trick to fix this issue?
I have the same issue, but it doesn't seem common
regarding control of motor speed
can i run the vesc motor at full speed for all time without using transmitter and reciever.
Vesc tool 2.02 not starting on windows 10
Unfortunately I can't even start the tool on windows,
I copied exe file to desktop and when I double click it, it shows an error message."vesc 2.02 exe stopped working" Windows will close the program.
Any ideas?
what i have to do when i
what i have to do when i bricked one of my 2 vescs? please help
Windows wont open tool
Hi! Нave you solved this
Hi! Нave you solved this problem?
Motor Types
which types of motors are supportred by the VESC controller
can we use it with all AC and DC motors?
can we use it with PMSM?
or only BLDC?
Thanks,
Mohamed
не могу купить vesk tool .
Que problema puede haber si mi esc no se conecta con vesc tool ?
Que problema hay si mi esc no conecta con vesc tool ????
Hi good afternoon.
on my macb i=ook pro wionbt coinnect
to the usb cables and ion my windows computer it is windows 10 an d it will start to open r\then the screen goes grey
Do I have to have windows to get into vesc bin trying for days
