VESC Tool manuals (non video based)
Submitted by frank on Tue, 2017-10-03 19:42
Comments
What kind of Operating System on my computer do i need to use the VESC Tool?
Greetings
Schlawiner
I am currently setting up my ESC using motor setup wizard, however, when asked to run the detection for the parameters, my motor does not cooperate. I have gone through both FOC and BLDC, however neither are working. Any advice for how to make it work. I am using a torque board motor 6353/190KV and my battery that I am trying to set it up with is 4 cells 5.2 A, 14.8V. I plan on running my longboard with two of these LiPo batteries
Hi mjmarchetto
maybe you got it working in the meantime, but I guess you are facting the same problem as I that your setup has a high inertio, so the overcurrent protection got in between. Try to set the eRPM (500afaik) in the detection lower for FOC. For BC (called BLDC here) I did not get mine working at all; as I got not feedback how to tweak the setup I was unable to get further on that front, but as FOC works as it should (so far) it's OK for me.
Cheers
Sam
Hi, i seem to be having trouble simply connecting to my dual FOCBox setup.... it says something about delay semaphore expired could it have something to do with baud rate?
Zoom zoom
I am trying to install bldc tool on windows 10 but instalation crashes on startup is there any trick to fix this issue?
Been googling around for VESC tool errors and I'm not coming up with much. There might be some specific compatability issues here. What kind of error code were you getting btw (if you still have it, I realize this was 6 months ago.)  I'm gettting a 0xc5
Unfortunately I can't even start the tool on windows,
I copied exe file to desktop and when I double click it, it shows an error message."vesc 2.02 exe stopped working" Windows will close the program.
Any ideas?
Mac Motor
