This guide shows you how to change the firmware, just in case you have the wrong firmware on your device, or you need to upload a special firmware.
In this tutorial we assume someone has the 410 firmware (for use with HW 4.10-4.12) installed on his VESC 6.x.
Don't use your VESC motor controller until you changed to the correct firmware, compatible with your VESC hardware.
The firmware for VESC SIX can be found here: https://github.com/vedderb/bldc/blob/master/build_all/60/VESC_default.bin?raw=true
Wrong firmware is likely to destroy your hardware. Always make sure to use the firmware that is designed for your hardware revision number.
Congratulations, you have successfully change to the correct firmware!
Comments
Uart signal
i suspect my uart doen’t work. To be sure i checked the tx with my oscilloscope and the signal is 3,4 volts but without pulses when the motors is running with the ppm remote
The vesc 6 is set to ppm+uart, 9600 bauds.
what is wrong?
I'm happy I found this web
I'm happy I found this web site, I couldn't find any information on this matter prior to. Also work a site and if you are ever interested in doing some visitor writing for me if possible feel free to let me know, I know your know-how on this. I must say we should have an online conversation on this. If you are ever interested in doing some visitor writing for me if probable feel free to let me know, I’m always look for people to check out my best essay writing service web site. Writing only commentary will close the discussion without delay away! And will restrict the benefits from this in turn.
Take it else where
What the hell are you talking about. Why don't you take that somewhere else? You have nothing to say about vesc, nothing to say about helping, nothing to say about anything that pertains to these ESCs and you said that talking about nothing would close the form? Why are you on here trying to close the discussion? makes no sense dude.
Love this game so much! Let's
Love this game so much! Let's share it with many people, because it is a great game. Too awesome Drift Hunters
Get your useless crap out of here.
What the subject field says.
nice
This is useful information, but I need more, can you write more about it? run 3
Three of you?
Three too many imbeciles taking up resources.
Great
I installed the wrong firmware on my device and I followed your instructions fleeing the complex, really helpful for me.
I agree wrong firmware is
I agree wrong firmware is likely to destroy your hardware. Always make sure to use the firmware that is designed for your hardware revision number. What do you think about death run 3d?
So cool
What you bring it means a lot, not only for me but for many people. Do you know stickman boost? it like that.
