Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
Downloading Qt is harder than you would think as by default it isn't downloaded when following the download instructions. The installer has a page with checkbuttons to pick what to download. You have to go down within the Qt box (Not the previews one) which looks like it has already been selected, and then somewhere in there select Qt 5.10...
That may have slowed me down a bit this morning...
Nursingexpert's picture
We are aware of the significance of grades and marks throughout your academic career. As a result, we take great care to produce an Nursing Essay Writing Services of the highest caliber for you. Your essay's content will be developed by our experts in a way that satisfies all of your professor's requirements, ensuring that you submit work that will be well-received.
Recently, I've been venturing into some enjoyable games to escape the monotony of the everyday life, and it's been a welcome diversion. But when I take mental breaks from gaming, I can't help but think of interesting Dissertation Topics For Economics. The way these two seemingly unconnected worlds converge to offer a singular viewpoint on leisure and intellectual pursuits is fascinating.
One more step should be added concerning the kit build and run kit.
By default I had another version that didn't work.
For beginners, it can be confusing.
Ubuntu 18-04
I have compiled with qt 5.11.1 and 5.10.1 but i got some error with non existing GL.h
Following packages will fix this error.
sudo apt-get install mesa-common-dev libgl1-mesa-dev libglu1-mesa-dev
Good mornig,
I'm trying to compile the latest version of vesc firmware. I've an old 4.12 version. After changing the hardware version and uploading the firmware nothing work, vesc is not recognized by vesc-tool. I've seen that there are substantial modification also in conf_general.h, like there no exist more #define HW_VERSION but instead HW_SOURCE and HW_HEADER, so: there are other modification in conf_general that i must make in order to properly config my vesc?
Thank you
Elia
I have spent hours trying to figure out how to compile the vesc-tool for my android. It keeps giving me an error saying that it cant find the serialbus module when opening the .pro file. A google search came up with one answer that didnt work. I am running Qt 5.10.1. I also tried 5.12 and 5.13. neither worked. If anyone knows how to fix this, (or even a VM of everything) any help would be appreciated.
Thanks,
Andrew Cline
Andrew Cline
after make and upload showing error
openocd -f board/stm32f4discovery.cfg -c "reset_config trst_only combined" -c "program build/BLDC_4_ChibiOS.elf verify reset exit" # For openocd 0.9
/bin/sh: 1: openocd: not found
Makefile:289: recipe for target 'upload' failed
make: *** [upload] Error 127
It has been discovered that not all versions of gcc produce working binaries. (https://github.com/vedderb/bldc/issues/210)
the latest version of gcc that works on ubuntu 20.04 and builds working binaries can be found here: https://developer.arm.com/tools-and-software/open-source-software/develo...
For compiling vesc tool it now seems like following the instructions in the build_lin and build_win scripts is the way to go. some dependencies need to be swapped out depending on ubuntu version though.
this seems to have changed to a new architecture. can someone explain the new process ?
conf_general.h doesn't contain all hw_***.h anymore
Assignmentspro's picture
Our Assignment Writing Service will create a 100% custom written assignment that will help you to be the best. We work with a Professional Assignment Writers team of UK based writers who, following your requirements and instructions, will develop a model answer which is flawlessly structured, well-sourced and written in perfect English.
What you provided was exactly what I needed. I've looked everywhere, but no one has anything fresh to give. I've subscribed to your feed and eagerly await your next update. If you have time, please come join us in run 3 or among us
For sure, the total aspect of the game is struck for the candidates. The joy of the Tools Dorset is invited for the range. Its branch is filed for the offers. Value is germinated for the top of the cycled items for the ranked element for the sequencing by all chunks.
as
This is a great post. I like this topic. This site has lots of advantages. I found many interesting things on this site. It helps me in many ways. Thanks for posting this again stumble guys
Your blog provided us with valuable information to work with. Each & every tips of your post are awesome. Thanks a lot for sharing. Keep blogging, Waffle unlimited
CureCloudMD's picture
Want to hire the best rehab billing services company in the USA? Get started with CureCloudMD which provides cost-effective, reliable, and HIPAA-compliant medical billing services across more than 30 specialties in the healthcare field. We provide a complete range of administrative services including medical credentialing, provider enrollment, revenue cycle management, medical billing and coding, account receivable recovery services, and customer support solutions.
 The advantages of playing word search go beyond than you might originally think, from preventing dementia to assisting with language learning.
We provide premium full grain leather since it adds to the durability and long life of the garment and is only possible with the best materials and craftsmanship. Consequently, you can choose from a variety of superb leather jackets made of calfskin, goatskin, cowhide, sheepskin and lambskin. Our Website The Designer Jackets is an outstanding selection of leather bombers and biker jackets,
Visit Here:
women bomber jacket
Engaging in transformative leadership coaching https://chaselearning.org/ on this platform has been a defining experience for me as a student. It goes beyond traditional education, molding managers into visionary leaders. The emphasis on practical skills, strategic thinking, and a holistic leadership approach has broadened my perspective. It's not just about managing; it's about inspiring and leading with a vision. As a student, this journey has equipped me with the tools to navigate the dynamic landscape of leadership and make a meaningful impact.
Thanks a lot for information, was searching for similar one.
English essay writing can be challenging, but with get essay help, I can now tackle my assignments with confidence. Their essay writers are experts in English, offering me prompt and professional assistance. Their essay writing tutor has helped me improve my writing skills and excel in my English essays.
Here is a tutorial on how to set up a Django development environment on Ubuntu 16.04 and later LTS releases. It includes installing Python 3, pip 3, Django and virtualenv in order to provide you with the tools necessary for developing web applications with Django Flappy Bird
Learn how to install a Django development environment on Ubuntu 16.04 and later Long Term Support (LTS) releases with this guide. You'll have everything you need to create Django-based web apps, including Python 3, pip 3, Django, and virtualenv. basketball stars
Engaging a professional assignment writing service ensures a high standard of work, providing students with expertly crafted assignments that meet academic requirements and contribute to overall learning.
Whether you are a new gamer or a fan from the beginning, Super Mario will never disappoint you. Get ready to embark on this exciting adventure and become the hero we've all been waiting for!
Students have been facing difficultuies to submit their dissertation at university,Iam always available for this type of students.We offer an online the best
dissertation service to help the students.
The article on https://profitworks.ca/blog/1048-8-digital-marketing-trends-2024-that-will-affect-your-seo.html about 2024 digital marketing trends is a gem for marketers seeking a strategic edge. The predictions are comprehensive, and the focus on SEO implications is a key takeaway, guiding me to refine my approach for sustained success in the dynamic digital space.
All of the information you put in your post is good and can be very helpful. I'll remember it. Thanks for sharing the information. Please keep posting new information age of war game
buy best academic writing services
Rich Text Editor, edit-comment-body-und-0-value
Rich Text Editor, edit-comment-body-und-0-valueedit-comment-body-und-0-value
it can be overwhelming to navigate through the sea of options available online. To make things easier for you, we've compiled a list of the top websites that offer high-quality assignment writing service
Heardle commitment to player satisfaction is evident in its regular updates and new challenges. The game evolves, offering a constant source of excitement for its dedicated community.
I will be grateful to you for your post; I have been hunting for an article like this for a considerable amount of time, and I finally found it today. This piece offers me a wonderful deal of guidance, and I find that it is of great assistance to me. globle game
Among Us is a social deduction game developed by InnerSloth that gained immense popularity in 2020.
