sudo apt update
sudo apt upgrade
sudo apt install build-essential openocd git libudev-dev qt-sdkNow install the gcc-arm-embedded toolchain (see this page for more details)
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppapress Y, enter, then
sudo apt update
sudo apt install gcc-arm-embeddednow add udev rules to use the stlink v2 programmer without beeing root
sudo udevadm triggerAt this point you should be able to clone the firmware from github, build it and upload it. Let's give it a try
cd vesc_firmware
makeby default this will build firmware for hardware version 6. To change the hardware version, open conf_general.h and change it to use the hardware version that you have. For example, for HW 4.12 it should look like this
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endifthere are also many other options that can be changed in conf_general.h. To rebuild the firmware after the changes, run
makenow connect the stlink v2 programmer, connect power from a lab power supply and try to upload the firmware
make uploadIt should say verified ok towards the end if everything went well.
VESC Tool
cd Downloads
sudo ./qt-unified-linux-x64-3.0.2-online.runfollow the instructions to finish the installation. You might also need the following packages:
git clone https://github.com/vedderb/vesc_tool.git vesc_toolIt is recommended to open the project file from Qt Creator (which you should have after the previous step) and build the project from there. Instructions for building the android version will be added later.
Comments
Hint for downloading Qt
Downloading Qt is harder than you would think as by default it isn't downloaded when following the download instructions. The installer has a page with checkbuttons to pick what to download. You have to go down within the Qt box (Not the previews one) which looks like it has already been selected, and then somewhere in there select Qt 5.10...
That may have slowed me down a bit this morning...
Nursing Paper Help in UK
We are aware of the significance of grades and marks throughout your academic career. As a result, we take great care to produce an Nursing Essay Writing Services of the highest caliber for you. Your essay's content will be developed by our experts in a way that satisfies all of your professor's requirements, ensuring that you submit work that will be well-received.
Looking for expert assistance
Looking for expert assistance with your academic papers? Look no further than write my paper www.essayshark.com ! Our dedicated team of experienced writers is ready to tackle any assignment, from essays to research papers and everything in between. With a focus on quality, originality, and meeting deadlines, we guarantee that your paper will be tailored to your specifications and delivered on time. Plus, our affordable rates make professional writing help accessible to students of all budgets. Say goodbye to late-night stress and hello to top grades with. Trust us to help you succeed in your academic journey!
Connections NYT - Online
ok
Fun Games
I had a much slower time than you Fun Games
Dissertation Topics For Economics
Recently, I've been venturing into some enjoyable games to escape the monotony of the everyday life, and it's been a welcome diversion. But when I take mental breaks from gaming, I can't help but think of interesting Dissertation Topics For Economics. The way these two seemingly unconnected worlds converge to offer a singular viewpoint on leisure and intellectual pursuits is fascinating.
Geometry Dash tasks players with guiding a geometric icon through a series of levels, avoiding spikes, gaps, and other hazards along the way.
Survival race
Readers' comments should be given more attention when viewed and shared Survival race.
wacky flip
Objectively, the information provided is quite suitable for users wacky flip.
Looking for a safe place to play online casinos in Australia? Then you should definitely check this out! At https://luckymatecasino.vip/ they have only trusted and licensed casinos. After reading the reviews, I joined a few casinos and started winning. This site has become my best assistant in the world of online gaming. Guys, for Australians, this is a real gem!
Eggy Car
In addition to being a fun hobby, Eggy Car serves as a reminder to me of the value of perseverance and patience. I've learned with each egg drop that failure is only an opportunity to try again.
papa's freezeria
Consistency in quality and design earns repeat business and five-star reviews papa's freezeria.
Tips for Downloading Qt
Expand the Qt box to see the available versions. This sports games often overlooked since it appears selected by default. If you encounter any issues during the installation, consider checking forums or the Qt support community for help. It can be a bit tricky at first, but once set up, Qt offers a powerful framework for application development!
jacksmith
You’ve got a knack for crafting weapons that feel tailor-made for each beast’s personality Jacksmith.
In the baby in yellow, you
In the baby in yellow, you must navigate eight chapters of nightmares in a bizarre apartment. Keep the baby fed, change diapers on time, and absolutely do not let it get angry. Will you survive your shift, or will you become the next victim of the dark forces lurking behind those big, round eyes?
Qt libraries
One more step should be added concerning the kit build and run kit.
By default I had another version that didn't work.
For beginners, it can be confusing.
Download link
http://download.qt.io/official_releases/qt/5.10/5.10.1/qt-opensource-lin...
gl error
Ubuntu 18-04
I have compiled with qt 5.11.1 and 5.10.1 but i got some error with non existing GL.h
Following packages will fix this error.
Vesc doesn't work after "make upload"
Good mornig,
I'm trying to compile the latest version of vesc firmware. I've an old 4.12 version. After changing the hardware version and uploading the firmware nothing work, vesc is not recognized by vesc-tool. I've seen that there are substantial modification also in conf_general.h, like there no exist more #define HW_VERSION but instead HW_SOURCE and HW_HEADER, so: there are other modification in conf_general that i must make in order to properly config my vesc?
Thank you
Elia
Ti consiglio di controllare attentamente tutte le modifiche nece
Ti consiglio di controllare attentamente tutte le modifiche necessarie in conf_general.h and time card calculator e di assicurarti che siano correttamente configurate per il tuo VESC.
Project ERROR: Unknown module(s) in QT: serialbus
I have spent hours trying to figure out how to compile the vesc-tool for my android. It keeps giving me an error saying that it cant find the serialbus module when opening the .pro file. A google search came up with one answer that didnt work. I am running Qt 5.10.1. I also tried 5.12 and 5.13. neither worked. If anyone knows how to fix this, (or even a VM of everything) any help would be appreciated.
Thanks,
Andrew Cline
showing error when uploading file in ubuntu
after make and upload showing error
openocd -f board/stm32f4discovery.cfg -c "reset_config trst_only combined" -c "program build/BLDC_4_ChibiOS.elf verify reset exit" # For openocd 0.9
/bin/sh: 1: openocd: not found
Makefile:289: recipe for target 'upload' failed
make: *** [upload] Error 127
working gcc versions
It has been discovered that not all versions of gcc produce working binaries. (https://github.com/vedderb/bldc/issues/210)
the latest version of gcc that works on ubuntu 20.04 and builds working binaries can be found here: https://developer.arm.com/tools-and-software/open-source-software/develo...
For compiling vesc tool it now seems like following the instructions in the build_lin and build_win scripts is the way to go. some dependencies need to be swapped out depending on ubuntu version though.
Howto for building VESC Tool for Android
For those who want to modify/contribute to the Android app, I've compiled a howto for creating the build environment in a VM (Ubuntu 18.04 ) that will produce an installable Android APK. The APK was successfully installed and tested on a phone running Android 11. The guide can be found here: https://gist.github.com/gmurdocca/0b72583aca5572577b409f29f0c923a1
I am really touched by this
I am really touched by this topic. Helping the homeless is not an easy thing and I am so happy that he is doing a great job in this corner. I really wanna convey this through my https://www.resumehelpaustralia.com/the-resume-writers-review/ blog articles to people and let them know who ever are homeless can get a shelter there.
this seems to have changed to a new architecture. can someone explain the new process ?
conf_general.h doesn't contain all hw_***.h anymore
Our Assignment Writing
Our Assignment Writing Service will create a 100% custom written assignment that will help you to be the best. We work with a Professional Assignment Writers team of UK based writers who, following your requirements and instructions, will develop a model answer which is flawlessly structured, well-sourced and written in perfect English.
What you provided was exactly
What you provided was exactly what I needed. I've looked everywhere, but no one has anything fresh to give. I've subscribed to your feed and eagerly await your next update. If you have time, please come join us in run 3 or among us .
Tools Dorset
For sure, the total aspect of the game is struck for the candidates. The joy of the Tools Dorset is invited for the range. Its branch is filed for the offers. Value is germinated for the top of the cycled items for the ranked element for the sequencing by all chunks.
This is a great post. I like this topic. This site has lots of advantages. I found many interesting things on this site. It helps me in many ways. Thanks for posting this again stumble guys
Great
Your blog provided us with valuable information to work with. Each & every tips of your post are awesome. Thanks a lot for sharing. Keep blogging, Waffle unlimited
good
I'm excited to explore more about the story and how
That's Not My Neighbor game explores horror in a cold 1950s office setting.
Drift Hunters game is packed
Drift Hunters game is packed with features that are powerful, so you will require a high-speed internet connection necessary to play the game.
Want to hire the best rehab billing services company in the USA? Get started with CureCloudMD which provides cost-effective, reliable, and HIPAA-compliant medical billing services across more than 30 specialties in the healthcare field. We provide a complete range of administrative services including medical credentialing, provider enrollment, revenue cycle management, medical billing and coding, account receivable recovery services, and customer support solutions.
good
The advantages of playing word search go beyond than you might originally think, from preventing dementia to assisting with language learning.
We provide premium full grain leather since it adds to the durability and long life of the garment and is only possible with the best materials and craftsmanship. Consequently, you can choose from a variety of superb leather jackets made of calfskin, goatskin, cowhide, sheepskin and lambskin. Our Website The Designer Jackets is an outstanding selection of leather bombers and biker jackets,
Visit Here:
women bomber jacket
Engaging in transformative
Engaging in transformative leadership coaching https://chaselearning.org/ on this platform has been a defining experience for me as a student. It goes beyond traditional education, molding managers into visionary leaders. The emphasis on practical skills, strategic thinking, and a holistic leadership approach has broadened my perspective. It's not just about managing; it's about inspiring and leading with a vision. As a student, this journey has equipped me with the tools to navigate the dynamic landscape of leadership and make a meaningful impact.
Thanks a lot for information,
Thanks a lot for information, was searching for similar one.
English essay writing can be challenging, but with get essay help, I can now tackle my assignments with confidence. Their essay writers are experts in English, offering me prompt and professional assistance. Their essay writing tutor has helped me improve my writing skills and excel in my English essays.
Here is a tutorial on how to
Here is a tutorial on how to set up a Django development environment on Ubuntu 16.04 and later LTS releases. It includes installing Python 3, pip 3, Django and virtualenv in order to provide you with the tools necessary for developing web applications with Django Flappy Bird
online assignment writing service
or more ideas. If you don't have time to find a place to stay, you can always rent an airport limo and just ride in it while it's waiting for more passengers. online assignment writing service
Learn how to install a Django
Learn how to install a Django development environment on Ubuntu 16.04 and later Long Term Support (LTS) releases with this guide. You'll have everything you need to create Django-based web apps, including Python 3, pip 3, Django, and virtualenv. basketball stars
Engaging a professional assignment writing service ensures a high standard of work, providing students with expertly crafted assignments that meet academic requirements and contribute to overall learning.
great
Whether you are a new gamer or a fan from the beginning, Super Mario will never disappoint you. Get ready to embark on this exciting adventure and become the hero we've all been waiting for!
Join the merging madness in
Join the merging madness in the Watermelon Game – a unique fruit-matching journey where identical fruits collide, evolve, and present an exciting challenge for all players.
I have read all the comments
I have read all the comments Happy wheels unblocked and suggestions of visitors for this article are very good, We will wait for your next article. Thank! Temple run 3
UK Assignment Writing Services
Iam a professional UK Assignment Writing Services Provider.I have submitted and help many assignments to the students to secure a good marks at their academic carrier.
Dissertation service
Students have been facing difficultuies to submit their dissertation at university,Iam always available for this type of students.We offer an online the best
dissertation service to help the students.
The article on https://profitworks.ca/blog/1048-8-digital-marketing-trends-2024-that-will-affect-your-seo.html about 2024 digital marketing trends is a gem for marketers seeking a strategic edge. The predictions are comprehensive, and the focus on SEO implications is a key takeaway, guiding me to refine my approach for sustained success in the dynamic digital space.
No Internet Game is not only
No Internet Game is not only about overcoming obstacles but also about fighting with yourself. I always feel excited when I beat my own records and see myself improving my skills.
All of the information you put in your post is good and can be very helpful. I'll remember it. Thanks for sharing the information. Please keep posting new information age of war game
