sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
Hint for downloading Qt
Downloading Qt is harder than you would think as by default it isn't downloaded when following the download instructions. The installer has a page with checkbuttons to pick what to download. You have to go down within the Qt box (Not the previews one) which looks like it has already been selected, and then somewhere in there select Qt 5.10...
That may have slowed me down a bit this morning...
Qt libraries
One more step should be added concerning the kit build and run kit.
By default I had another version that didn't work.
For beginners, it can be confusing.
Download link
http://download.qt.io/official_releases/qt/5.10/5.10.1/qt-opensource-lin...
gl error
Ubuntu 18-04
I have compiled with qt 5.11.1 and 5.10.1 but i got some error with non existing GL.h
Following packages will fix this error.
Vesc doesn't work after "make upload"
Good mornig,
I'm trying to compile the latest version of vesc firmware. I've an old 4.12 version. After changing the hardware version and uploading the firmware nothing work, vesc is not recognized by vesc-tool. I've seen that there are substantial modification also in conf_general.h, like there no exist more #define HW_VERSION but instead HW_SOURCE and HW_HEADER, so: there are other modification in conf_general that i must make in order to properly config my vesc?
Thank you
Elia
Project ERROR: Unknown module(s) in QT: serialbus
I have spent hours trying to figure out how to compile the vesc-tool for my android. It keeps giving me an error saying that it cant find the serialbus module when opening the .pro file. A google search came up with one answer that didnt work. I am running Qt 5.10.1. I also tried 5.12 and 5.13. neither worked. If anyone knows how to fix this, (or even a VM of everything) any help would be appreciated.
Thanks,
Andrew Cline
showing error when uploading file in ubuntu
after make and upload showing error
openocd -f board/stm32f4discovery.cfg -c "reset_config trst_only combined" -c "program build/BLDC_4_ChibiOS.elf verify reset exit" # For openocd 0.9
/bin/sh: 1: openocd: not found
Makefile:289: recipe for target 'upload' failed
make: *** [upload] Error 127
working gcc versions
It has been discovered that not all versions of gcc produce working binaries. (https://github.com/vedderb/bldc/issues/210)
the latest version of gcc that works on ubuntu 20.04 and builds working binaries can be found here: https://developer.arm.com/tools-and-software/open-source-software/develo...
For compiling vesc tool it now seems like following the instructions in the build_lin and build_win scripts is the way to go. some dependencies need to be swapped out depending on ubuntu version though.
Howto for building VESC Tool for Android
For those who want to modify/contribute to the Android app, I've compiled a howto for creating the build environment in a VM (Ubuntu 18.04 ) that will produce an installable Android APK. The APK was successfully installed and tested on a phone running Android 11. The guide can be found here: https://gist.github.com/gmurdocca/0b72583aca5572577b409f29f0c923a1
I am really touched by this
I am really touched by this topic. Helping the homeless is not an easy thing and I am so happy that he is doing a great job in this corner. I really wanna convey this through my https://www.resumehelpaustralia.com/the-resume-writers-review/ blog articles to people and let them know who ever are homeless can get a shelter there.
this seems to have changed to a new architecture. can someone explain the new process ?
conf_general.h doesn't contain all hw_***.h anymore
Our Assignment Writing
Our Assignment Writing Service will create a 100% custom written assignment that will help you to be the best. We work with a Professional Assignment Writers team of UK based writers who, following your requirements and instructions, will develop a model answer which is flawlessly structured, well-sourced and written in perfect English.
What you provided was exactly
What you provided was exactly what I needed. I've looked everywhere, but no one has anything fresh to give. I've subscribed to your feed and eagerly await your next update. If you have time, please come join us in run 3 or among us .
