BESC 150V 200A
82 posts / 0 new
galp
BESC 150V 200A
Hi!
Main parts used:
BESC top
BESC top
BESC bottom
bmlski
galp
bmlski
galp
galp
Hey galp,
galp
de-bodgery
de-bodgery's picture
galp
de-bodgery
galp
future BESC v1
Future BESC v1 top
Future BESC v1 bottom
galp
PCBs are here.
BESC init PCB
tul00985
galp
Last seen: 1 week 1 day ago
larsrocket
galp
BESC init
BESC Phase voltages
Phase voltages
BESC phase current
Phase currents - motor start
Any ideas?
galp
galp
galp
A bit of status update:
How BESC looks now:
BESC init
BESC init
  • Get ringing under control
  • Separate analog supply
  • Shield 8 MHz xtal​
Top side:
BESC v1
Bottom side:
BESC v1
BESC v1
Any thoughts?
galp
larsrocket
galp
shaman
Last seen: 8 months 5 days ago
@galp
bgdwiepp
Last seen: 1 year 2 weeks ago
galp
bgdwiepp
galp
bgdwiepp
galp
BESC capacitor bank
Or even better:
BESC power bank 2
HoltRead
pcb prototype
galp
BESC v1.1b
BESC v1.1b
BESC housing
shaman
maris
galp
PCBs arrived:
BESC V1.1b top
BESC V1.1b bottom
galp
galp
galp
Good news! laugh
Gate voltage at transition:
Test run:
AlexBenn
AlexBenn
