BESC 150V 200A
82 posts / 0 new
galp
BESC 150V 200A
Hi!
Main parts used:
BESC top
BESC top
BESC bottom
bmlski
galp
Last seen: 1 month 14 hours ago
bmlski
galp
galp
Hey galp,
galp
de-bodgery
de-bodgery's picture
galp
de-bodgery
galp
future BESC v1
Future BESC v1 top
Future BESC v1 bottom
galp
PCBs are here.
BESC init PCB
tul00985
galp
larsrocket
galp
BESC init
BESC Phase voltages
Phase voltages
BESC phase current
Phase currents - motor start
Any ideas?
galp
galp
galp
A bit of status update:
How BESC looks now:
BESC init
BESC init
  • Get ringing under control
  • Separate analog supply
  • Shield 8 MHz xtal​
Top side:
BESC v1
Bottom side:
BESC v1
BESC v1
Any thoughts?
galp
larsrocket
galp
shaman
@galp
bgdwiepp
galp
bgdwiepp
galp
bgdwiepp
galp
BESC capacitor bank
Or even better:
BESC power bank 2
HoltRead
pcb prototype
galp
BESC v1.1b
BESC v1.1b
BESC housing
shaman
maris
galp
PCBs arrived:
BESC V1.1b top
BESC V1.1b bottom
galp
galp
galp
Good news! laugh
Gate voltage at transition:
Test run:
AlexBenn
Last seen: 1 year 1 week ago
AlexBenn
