2. Motor Setup Wizard
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Vesc-Tool_MSM_intro
Vesc-Tool_MSW_wiring
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Vesc-Tool_MSW_connect
Vesc-Tool_MSW_start
Vesc-Tool_MSW_default
VESC-Tool MSW_choose FOC
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
Vesc-Tool_FW_current limits warning
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current.  Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Vesc-Tool_MSW_current limits set
Vesc-Tool_MSW_battery cutoff_warning
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
VESC-Tool MSW_battery cutoff_set values
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the  the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Vesc-Tool_MSW_select sensors
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Vesc-Tool_MSW_motor parameter_01
Vesc-Tool_MSW_motor parameter_02
Vesc-Tool_MSW_motor parameter_03
Vesc-Tool_MSW_motor parameter_04
Vesc-Tool_MSW_motor parameter_05
Vesc-Tool_MSW_sensor calibration_01
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Vesc-Tool_MSW_sensor calibration_02
Vesc-Tool_MSW_sensor calibration_03
Vesc-Tool_MSW_finish
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
I never thought I’d need help writing term paper until I got swamped with assignments. The service I found offered a team of term paper writer service who were so efficient and reliable. They not only completed my paper on time but also ensured it was free of errors and properly formatted. If you’re struggling with time management or the complexity of your papers, I highly recommend giving them a try. It’ll take a lot of pressure off your shoulders and help you meet deadlines.
I don’t usually gamble much, but sometimes I like to try my luck for fun. I was looking for a decent casino site with fair games and found https://crackbye.com/. The site looks nice, works fast, and has plenty of options. What caught my attention were the bonuses – they actually give good deals that make playing more enjoyable. I played a few rounds and managed to win some cash, which I easily withdrew.
Feeling overwhelmed by your online classes? You’re not alone! Many students struggle to keep up with coursework, especially in today’s fast-paced digital learning environment. If you’re looking for support, consider saying, “Take my online class!” Our expert tutors are here to help you navigate your studies, ensuring you stay on track and achieve your academic goals.
The Motor Setup Wizard is a useful tool for configuring motor parameters efficiently. It simplifies the setup process, ensuring optimal performance by guiding users through key settings like voltage, current limits, and control modes. Proper configuration enhances motor efficiency and prevents operational issues.
For students working on engineering or automation projects, understanding motor setup is essential. If you need assistance with technical assignments, MyAssignmentHelp’s assignment writing service provides expert support. Their professionals ensure precise, well-structured solutions to help you excel in your academic work.
With a team of experienced accountants, expert bookkeepers, accounting resources aided by advanced Accounts Receivable tools and software, Back Office Accountants provides the best-outsourced Accounts Receivable Services in the market. accounts receivable services
Phantom Wallet for Chrome is a fast, secure, and easy-to-use cryptocurrency wallet designed for managing Solana and Ethereum-based assets. With its sleek interface, users can store, send, and receive tokens, interact with decentralized applications (dApps), and manage their NFTs seamlessly. Phantom Wallet also offers enhanced privacy, security, and support for staking, providing a complete solution for crypto enthusiasts and users of Web3 platforms. Phantom Wallet Chrome | Phantom Chrome Extension
I was struggling to find a tool that could handle my LinkedIn outreach tasks efficiently. That’s when I came across this site: Explore the comparison between Dripify vs Linked Helper to uncover the perfect LinkedIn automation tool for your business needs. Dripify emerges as the leading Linked Helper alternative, offering a seamless way to automate repetitive LinkedIn tasks while optimizing your time management. Dripify provides advanced features that align perfectly with diverse business objectives. Whether you prioritize efficiency, ease of use, or superior results, Dripify empowers you to take control of your LinkedIn outreach and achieve your goals with unparalleled precision.. The comparison really helped me see the advantages of Dripify over Linked Helper. With its advanced features and focus on time management, it seemed like the perfect choice for automating my LinkedIn outreach.
Ledger.com/start to easily set up your Ledger hardware wallet and begin securing your cryptocurrency assets. Follow simple steps to protect your private keys and manage your digital assets safely. Ledger offers robust security features, including a secure chip and backup options, ensuring peace of mind for your investments. Get started today and take control of your crypto security with Ledger.
Ledger.com/start | Trezor wallet login
It is definitely one of the best gaming sites that I have ever seen online, it is available to everyone at this link, I spend a lot of time here myself, I am happy with everything, I hope you will also appreciate this site for its merits and will win only more and more actively than ever - Paradise8, the choice of the best!
After moving to a new city, I missed my old friends’ gatherings. Looked for something online to enjoy in my free time. Came across satta matka, a site with tons of matka options like Rajdhani. It’s got fast results and cool Indian-style bonuses—perfect for a quick thrill. I liked how simple it was to start and chat with others.
I recently found myself in Canada and was looking for something to do while I was alone. Looking for a new pastime, I decided to try
https://casinocanada.com/casinos/moonwin/ and it was a real discovery! The interface is user-friendly, the games are varied, and the bonuses were a pleasant surprise. While spending an evening in Vancouver, I won a small amount and felt a real thrill. Now that I am in Canada, this is my new hobby for relaxation!
Poki Games, Friv Games, and Crazy Games are three popular online gaming platforms, each with its own style. poki games offers a wide variety of fun, casual games in various genres, regularly updated with new titles, and is perfect for quick gaming sessions. friv games is known for its simple, no-signup-required platform with easy-to-play games, great for those who want a quick escape. crazy games on the other hand, focuses on high-quality, HTML5 games with a mix of multiplayer and indie titles, providing a more immersive gaming experience. Each platform caters to different gaming preferences, so the choice depends on what you're looking for whether it's variety, simplicity, or quality.
Assignment help services in UK provide expert academic assistance to students struggling with coursework, essays, and dissertations. With professional writers across various subjects, these services ensure high-quality, plagiarism-free content. Whether you need help with research, formatting, or deadlines, Myassignmenthelp.com offers reliable support for assignment help service in the UK.
Ledger.com/start to begin securing your crypto assets with the world’s most trusted hardware wallet. Get easy-to-follow setup instructions for Ledger devices, including Ledger Nano S and X, to store and manage your digital currencies safely. Start your journey toward secure crypto storage today with Ledger’s intuitive and user-friendly interface. Ledger.com/start | Trezor Wallet Login
MetaMask is a secure and user-friendly crypto wallet and gateway to blockchain apps. Easily manage Ethereum and other assets, interact with dApps, and enjoy seamless Web3 experiences directly from your Chrome browser. Trusted by millions, MetaMask ensures your digital identity and assets are always under your control. Install now to explore the decentralized web with confidence. Metamask Chrome Extension | Metamask Chrome
Recently, I was on the hunt for a platform where I could find the best software providers. That's when I found https://slotier.com/providers . It lists some of the top software companies, which means I can enjoy high-quality games every time I log in. The site is straightforward, and the bonuses like cashbacks are a nice touch. It's a good place for anyone who wants a great selection without too much hassle.
It's fascinating how some systems can be as thrilling as a casino experience – sometimes it's all about that adrenaline rush! For me, it's like a casino Only Win moment, when everything falls into place. Best of luck with the tuning and achieving great results!
Timing has always felt tricky for me—whether it’s starting projects or ending things. I wanted some guidance about life transitions and how to approach them more intentionally. The reader helped me explore cycles and how they show up personally. It made me feel more in sync with my own rhythm. I browsed https://psychics-advisor.com/city/miami/ right after and bookmarked a few more readers for seasonal check-ins. It gave me a fresh way to stay connected with my own process.
Great walk through on setting up VESC with FOC mode—very clear and helpful for beginners. Just like precision is key in configuring motor settings, professional painters in Philadelphia focus on every detail to ensure flawless finishes. Attention to detail makes all the difference, whether in electronics or home improvement projects.
Great tutorial for anyone getting started with VESC® configuration. Running motors in FOC mode really makes a difference in efficiency and smoothness. I’ve seen similar step-by-step setups help in medical equipment too, where reliable performance is key—especially when patients depend on accurate timing to Refill Scripts and keep treatments on track.
Great guide on setting up the VESC® motor controller! It's always helpful to have clear instructions for configuring different control modes. As a side note, when handling electrical systems and hardware, ensuring that your environment is safe from mold growth is crucial. If you're dealing with mold issues, don't hesitate to contact professionals for Florida mold insurance claims.
 Ignite your passion for music with  Sprunki Retake !  Choose your favorite icons and mix them into a great music. With each note, you will be free to be creative and express your personality.
