2. Motor Setup Wizard
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Vesc-Tool_MSM_intro
Vesc-Tool_MSW_wiring
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Vesc-Tool_MSW_connect
Vesc-Tool_MSW_start
Vesc-Tool_MSW_default
VESC-Tool MSW_choose FOC
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
Vesc-Tool_FW_current limits warning
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current.  Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Vesc-Tool_MSW_current limits set
Vesc-Tool_MSW_battery cutoff_warning
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
VESC-Tool MSW_battery cutoff_set values
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the  the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Vesc-Tool_MSW_select sensors
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Vesc-Tool_MSW_motor parameter_01
Vesc-Tool_MSW_motor parameter_02
Vesc-Tool_MSW_motor parameter_03
Vesc-Tool_MSW_motor parameter_04
Vesc-Tool_MSW_motor parameter_05
Vesc-Tool_MSW_sensor calibration_01
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Vesc-Tool_MSW_sensor calibration_02
Vesc-Tool_MSW_sensor calibration_03
Vesc-Tool_MSW_finish
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
Step 1:measure RL
Step 2:measure λ
Step 3:Apply values
Step 1:measure RL
Step 2:measure λ
Step 3:Apply values
Step 1:measure RL
Step 2:measure λ
Step 3:Apply values
Navigating the complexities of residency applications was easier with the help of residencypersonalstatements.net . Their comprehensive services covered every aspect of my personal statement, from initial drafting to final proofreading. The team’s deep understanding of what admission committees seek allowed them to create a statement that highlighted my strengths and unique experiences. Their professional support was crucial in presenting a polished and persuasive application, significantly enhancing my chances of securing a residency position.
Coinbase.com is a leading cryptocurrency platform that allows users to buy, sell, and manage digital currencies like Bitcoin, Ethereum, and more. With a user-friendly interface, secure storage, and educational resources, Coinbase simplifies crypto trading for beginners and experts alike.
Coinbase.com | Coinbase Extension
I’ve been a fan of online casinos for a while, and I wanted to try something new. That’s when I discovered https://gb.nongamstopbookiesuk.com/review/final-countdown/. The site has everything, from exciting slots to live dealer games. Their welcome bonus gave me extra funds to play with, and they seem to reward loyal players with interesting promotions.
Configuring your VESC® or VESC® based ESC with the VESC®-Tool Software can be challenging, especially for beginners. The software offers extensive customization, allowing users to fine-tune motor control, braking, and other settings. To simplify the process, "assignment writing services UK" from MyAssignmentHelp can provide detailed guidance on understanding VESC® settings and parameters, ensuring optimal performance. Key pointers include motor current settings, firmware updates, and customizing throttle response. With expert help, managing these configurations becomes seamless and effective.
Chơi đá gà trực tiếp thomo tại web choidaga88 sẽ nhận được tiền thưởng 3 triệu vào tài khoản ngay lập tức !
Choidaga88 đang đứng top 1 google trong mảng trực tiếp đá gà và cá cược đá gà cựa sắt !
Website: https://choidaga88.net/
Blog: https://choidaga88.blogspot.com/
Địa chỉ: Xóm Đất, Q11, TP HCM
SĐT: 0688889999
The Motor Setup Wizard is an essential tool for engineers and tech enthusiasts, simplifying motor configuration and setup with step-by-step guidance. For students tackling complex engineering assignments, this wizard can serve as a valuable reference point. If you’re struggling to complete assignments on similar technical topics, consider reaching out to MyAssignmentHelp's assignment writing services UK. They offer expert guidance and support, ensuring accurate and well-structured assignments tailored to meet your academic needs.
To jump or avoid obstacles you just need to tap the screen, each level of geometry dash requires precise timing to avoid spikes, pits and moving objects.
Setting the motor and battery current limits correctly is critical for the system to operate safely and efficiently. Starting with low values and gradually increasing them is a sensible approach to exploring the system's performance with confidence. Additionally, carefully setting the battery voltage cutoff values is important for preserving the battery's lifespan. As for motor sensors, using Hall sensors is particularly useful for ensuring smooth startup at low speeds. These explanations are really helpful. https://slopeplay.org
Unfortunately, this great game is blocked by some schools. You can play basketball stars without any obstacles on our site. Basketball stars is one of the best games among basketball games.The first version of the game is the basketball stars game published by y8. Later, in 2020, the basketball legends 2020 game was broadcast.
I was planning a fun night at home with some exciting games, so I looked up online casinos. That’s when I found prism casino. The site had everything from slots to poker and worked perfectly even on my older laptop. Their bonuses stood out—a big welcome package, reload offers, and free spins, all tailored to keep players engaged. Plus, they update their promotions regularly, which keeps things interesting. For me, it’s the ideal spot to enjoy gaming whenever I want.
Have you played Block Blast? What do you like most about the game? Share your thoughts!
I’ve been a sports enthusiast for years, but recently I discovered sports betting online on this platform. It was easy to start, and the odds they offer are quite appealing. They also have bonuses for new players, which allowed me to explore more betting options. The interface is smooth, and the betting process is simple and enjoyable.
I was bored one evening and decided to check out online slots for some entertainment. After looking around, I found https://slotscity.com/promotions/welcome-pack. They offer a welcome pack for new players, which is a great way to begin. The games are all very smooth, and there are plenty of options to keep you entertained for hours.
I was bored one evening and decided to check out online slots for some entertainment. After looking around, I found https://slotscity.com/promotions/welcome-pack . They offer a welcome pack for new players, which is a great way to begin. The games are all very smooth, and there are plenty of options to keep you entertained for hours.
Finding no-ID betting sites that offer fast withdrawals and diverse betting options can be tough, but this guide made it easy. The platforms  https://www.stjamestheatre.co.uk/betting-sites-no-id/ listed here are reliable and provide a seamless experience from start to finish. If you’re into stress-free betting, this resource is worth checking out.
