ADC and Uart reverse button
9 posts / 0 new
vufmihai
hello guys. im a begginer
I need some help connecting the reverse button on adc and uart
i dont know witch pins to connect on witch plugs
please help
thank you
Last seen: 3 months 17 hours ago
Please have a look here: https://vesc-project.com/node/914
RX to GND is the answer.
vufmihai
I have read the threads but i stil dont know were exactly i conect the button
Rx+ground is when i use only adc
I need to know were exactly i connect the wires when i use adc and uart
Witch port and witch wire
Thank you
vufmihai
come on guys im sure somebody can help me
Wytsem
I don't know if you figured it out yet but you can use ther servo/pwm input and in the app setting -> ADC -> General -> Control Type => use one of the options with reverse button.
This works for me with the vesc 6, hope you can use it if you hadn't already figured it out.
y-hasebe
y-hasebe's picture
Hi Vulmihai,
I have the same problem since I can't find where to connect the reverse button at ADC and Uart setting.
Could you solve this problem?
Hasebe
y-hasebe
y-hasebe's picture
Hi, I could change the direction to reverse by connecting RX pin to GND when the setting is ADC. However if I change the setting to ADC & UART the direction does not change. Anyone knows how to use reverse button with ADC & UART.
Hasebe
liteglow
Is it not possible to use Reverse on the VESC when also using a BT module ?
Bluetooth is the main reason to use VESC, but I`m helpless without Reverse.
anyone ?
supertiny808
supertiny808's picture
I'm about to try this, I was going ot disconnect my Bluetooth when using reverse but going to wire it in parallel so can keep the bluetooth plug. I'm also like to limit my speed in Reverse Only.. :)
808
