VESC 75/300, TP 100 inrunner 10KW
Markula
Hi
I have problems get the VESC motor controller to drive the TP100 inrunner motor:
http://www.tppower.com/sort.asp?class_id=4&news=110
TP100
Model No.
TP100
Slot & Pole
12 -Slot    10 -Pole
KV
   220Kv
Quiescent Current(10V)
        3A
Max Current
         200A
Vo
         48V
DC Resistance
    0.00625  to  0.0007325 ?
Max RPM
          25000RPM
Continuous Power
         10500W
Max Power
            23000W
Here is a video try to get the motor working in Sensorless mode. I have tryed small inrunner/large inrunner, hub motor. so on
I only turn trottle up 5% and the motor automatic raps itself up to full speed. So it only work like on/off. Revers do not work at all
https://youtu.be/CqSM3uZo7gY
I have a 60A ESC from china, it works fine with cheap brushless controllers.
You have the controller set to current control mode. Set it to duty cycle mode and the speed will be easier to control.
Markula
Hi
Yes, thanks now all work fine, revers too! :)
Markula
Hi
I did a test run with a small 15" boat today. 7 knots!
I had it running:
100A on battery load, 200A motor current.
Duty cycle was about 90%.
About 5000W of power.
But i want 200A battery load, i can use a smaller propeller. But will i get 200A on motor current ?
Also, when i hit a wave at 90% duty cycle, the extra load made the VESC to turn off. And i had to return the trottle back to nutral. And then i can start up again.
Some mode the VESC just deliver what it can, but dont stop ?
Last seen: 5 days 23 hours ago
You should probably use current control mode, and not duty mode. Duty cycle control is almost never useful in practical applications. Current control gives torque control, which explains why the motor spins up to full speed when there is no load. That is the expected and desired behavior.
Regarding the current at full modulation, I think you have to go to the General > Current page and increase the battery current to 200A.
Markula
ok i can change to curren controll mode. Motor and battery current is set to 220A. I was driving the boat at 195-200A and a wave hit the boat, current then is 220A+ and motor controller turn off. Then i have to set trottle to nutral and can start up again.
