Help with Built-in NRF24 and custom remote
16 posts / 0 new
solidgeek
solidgeek's picture
Hi folks :-)
So I have been working on a custom remote for the past week, planning to use the built-in NRF24-module on the VESC 6.4. However I have no idea, of where to start. I have tried using the "Input Setup Wizard" in the VESC-tool, however it can't seem to pair with my custom NRF-remote. Does anyone know how to set a nrf24l01 in this so-called "pairing mode"? I haven't been able to find any examples online, not even an Arduino-example.
If I am able to connect the two NRF-modules, how does the communication work? Do I send commands to the VESC and how can I get real-time data from the VESC across the same connection? Can't seem to find any information about this topic.
I hope some of you could shed some light upon this mystery :-D
- Emil
Boesila
Hi everyone,
Sorry for hitchhiking your thread, but I have a similar question. I'm struggling with the nyko karma nunchuk due to interrupted connection... Sometimes I'm not able to break or accelerate. That's why I want to build my own Nrf remote, too. But I cannot find a detailed description how to build it, which parts I need or where to buy a pcb with all necessary components already soldered.
Could somebody give me a suggestion?
Best, boesila
I think frank posted a wrong link and he means github.
You can find everything you need to now about building the hardware here: https://github.com/vedderb/nunchuk_rf_hw and the regarding firmware here: https://github.com/vedderb/nunchuk_mod
I haven't tested if the current available firmware of the nunchuk is working with the newest FW 3.25 of the VESC.
See, this is why the VESC-Project needs this website and build up a documentation. Maybe we can make some PCBs. I'll check that. Frank
Sanjoy
F/W is 3.26 on the vesc at the moment. i think new update available should be posted on here instead of only finding out when you connect to vesc tool. is that possible please Benjamin.
Sorry, copied the wrong link in and didn't realize it. Thx Hexakopter! Frank
solidgeek
solidgeek's picture
Hi Frank, I want to make a simple remote with a NRF-module and a Arduino for calculating etc. How can I use the built-in NRF-module for this? It would be easy to make a reciever board myself to connect PWM or UART input on the VESC 6, however I think its a shame not to utilize the built-in NRF :-)... The nunchuch mod Benjamin has been doing is awesome, however it is neither easy to produce yourself, nor copy onto your own project! Any help would be appreciated
- Emil
So you habe a project on the boil... If I had the time to design a remote it would have happened already. I think the fastest way forward is to have some PCBs made, exactly as the design shown. Frank
Pimousse
As Benjamin told us, we can consider Nunchuck mod firmware on Github completely compatible with VESC6 (3.26 currently), right ?
I think we are though in lack of documentation about communication with VESC (UART, can-bus or nRF now).
IMHO, it's a really important point because we are beta testing and we need tools to datalog/monitor the behaviour of the VESC.
Otherwise, if we encounter any issues, we can't give enough feedback to diagnose.
Aren't agree with that ?
Maybe you should have a look here for something arduino related: https://github.com/RollingGecko
EDIT.: Looks like there is a bug when reply to messages. I replied to #8 instead of #10.
Last seen: 3 weeks 6 days ago
The NRF firmware on my github is working, that's what I'm using myself.
Regarding the communication protocol, here is one file with almost the same same version:
https://github.com/vedderb/rise_sdvp/blob/master/Embedded/RC_Controller/...
The only difference is that the ADC app has two more options. That file and this post
http://vedder.se/2015/10/communicating-with-the-vesc-using-uart/
should be enough to get the communication running. I will collect this in the documentation pages soon.
Pimousse
I will take your Nunchuk mod FW as reference.
Thank you very much for clarifying this and for the future documentation.
solidgeek
solidgeek's picture
Hi Benjamin, thanks for the examples. You don't explain how to establish the connection between the built-in NRF-module and another NRF? My VESC 6 hasn't been able to connect to any NRF-module yet, how does one put a NRF24L01 module in this "pairing mode" you mention in the VESC-tool? :-) This is the first time I play around with a VESC at all, so forgive me if I have overlooked something - I am trying to learn as much as possible!
IRONSQUIRREL89
Last seen: 1 week 6 days ago
Hi Benjamin, are you able to recommend settings for using your nrf nunchuck mod with vesc 6. tx power?, speed?, crc?, etc.
i am having a problem that did not happen when using the nrf nunchuk with my vesc 4.12 and i want to make sure i have the correct settings.
m.juan
hi!
Did you manage to connect to the built-in nrf in the vesc with an arduino+nrf ?
I want to do the same thing but no idea how to configure nrf on arduino side to connect to the vesc.
I want to send data the vesc over nrf. but right now receiving alive packet from vesc on the arduino would be great enough....
