This is a TODO list for features in VESC Tool and in the VESC firmware. It will be updated on a regular basis.
Date Added | Task | Link | Status | Done in FW |
2017-09-05 | PPM reverse function with double tap. | 1 | Done | 3.58 |
2017-09-05 | Different throttle curves for forwards and reverse. | Done | 3.28 | |
2016-02-10 | Speed ramping. | 1 | TODO | |
2017-08-01 | Proper hall sensor support for BLDC | TODO | ||
2017-09-01 | Overcharge soft cutoff. | TODO | ||
2017-09-05 | NTC Beta factor configuration option. | 1 | Done | 3.28 |
2017-09-05 | Fix RT data timescale. | 1 | Done | 3.28 |
2017-09-05 | FW: Add board configuration file and set correct pin modes at boot. | Done | 3.28 | |
2017-09-06 | cPPM APP with mixing | 1 | TODO | |
2017-10-14 | Field weakening | 1, 2 | TODO | |
2017-10-17 | Online parameter changes | 1 | Done | 3.42 |
2017-10-26 | Different temperature cutoffs for acceleration and brake | Done | 3.30 | |
2017-11-06 | PID handbrake at full brake option when sensors are present. | 1 | TODO | |
2017-11-23 | Proper torque-controlled brake from 0 speed. | 1 | Done | 3.47 |
2018-03-06 | Step/Dir app for CNC applications and similar. | 1 | TODO | |
2018-03-16 | Support for pedal sensor in ADC app (legal requirement in some places). | 1 | TODO | |
2018-03-23 | APP_ADC: Safe start after braking feature. | 1 | TODO | |
2019-07-05 | Hall sensor and other hardware debugging support in VESC Tool | 1 | TODO |
To see a list of all changes between the firmwares, have a look at the changelog.
Comments
Source Code
Hi Benjamin,
According to the changelog, it seems that Github Firmware Source Code is still 3.33.
Can you upload the latest one, please?!
Max amp allowed with 6.4
Bonjour avec vesc 6.4 quelles sont les valeurs maximales applicables au courant du moteur, au courant de la batterie et au courant maxi?
Si je veux 2 vesc dans ma configuration, devrais-je compter la valeur × 2 ou l'ampère reste le même et gauche 50/50?
Merci d'avance pour vos réponses.
(No subject)
LOST
it says i need the latest firmware so i can program my Dual board. i have NO PROBLEM donating money but i cant until someone shows or tells me how to do it.
Can you do my homework cheap?
Can you do my homework cheap? Homeworkfor.me has highly qualified and experienced writers who can help you. You can be assured of excellent papers, prompt submission, affordable costs, and maximum security.
Great Post!
These a quite good tips. I too have a meeting with my team’s
marketing assignment help I have been planning this trip for a while now because I was nervous that I may forget some important thing at the end time but I think your tips will help me in this. Thank you so much for these tips, I hope your meeting was successful!
Get In Cheap Prices!
This is the first time that I visit here. I found so many exciting matters in this particular Forums, One thing I would like to request you that pls keep posting such type of Best Custom Leather Jackets Forums.
Friday Night Funkin is not
Friday Night Funkin is not what you think when looking at the first images of the poster. It's literally the funniest witty music I've ever played.
And the surprise is that it also has a storyline, not flying in and entering like other music games. No matter what the next steps are, in the beginning, I gave it an A+ because of the difference.
The story of the game is divided into several weeks, representing the encounters and challenges of the godfather for you. Each week there will be 3 different difficulty levels. The harder it is, the faster your rhythmic coordination as well as your speed of grasping the notes should be.
Truecaller
It can be said that Truecaller Premium APK (MOD Gold Member Unlocked) is one of the indispensable applications in your mobile device.
Captions
The article posted was very informative and useful. I really appreciate this wonderful post that you have provided for us. Thanks for this amazing post.
Traditional Instagram captions
Elite Passion
how can i change on my site?
Mumbai Call Girls
