Software TODO list
Submitted by benjamin on Tue, 2017-09-05 22:02
This is a TODO list for features in VESC Tool and in the VESC firmware. It will be updated on a regular basis.
Date Added Task Link Status Done in FW
2017-09-05 PPM reverse function with double tap. 1 Done 3.58
2017-09-05 Different throttle curves for forwards and reverse.   Done 3.28
2016-02-10 Speed ramping. 1 TODO
2017-08-01 Proper hall sensor support for BLDC   TODO
2017-09-01 Overcharge soft cutoff.   TODO
2017-09-05 NTC Beta factor configuration option. 1 Done 3.28
2017-09-05 Fix RT data timescale. 1 Done 3.28
2017-09-05 FW: Add board configuration file and set correct pin modes at boot.   Done 3.28
2017-09-06 cPPM APP with mixing 1 TODO
2017-10-14 Field weakening 1, 2 TODO
2017-10-17 Online parameter changes 1 Done 3.42
2017-10-26 Different temperature cutoffs for acceleration and brake   Done 3.30
2017-11-06 PID handbrake at full brake option when sensors are present. 1 TODO
2017-11-23 Proper torque-controlled brake from 0 speed. 1 Done 3.47
2018-03-06 Step/Dir app for CNC applications and similar. 1 TODO
2018-03-16 Support for pedal sensor in ADC app (legal requirement in some places). 1 TODO
2018-03-23 APP_ADC: Safe start after braking feature. 1 TODO
2019-07-05 Hall sensor and other hardware debugging support in VESC Tool 1 TODO
To see a list of all changes between the firmwares, have a look at the changelog.
Comments
Hi Benjamin,
According to the changelog, it seems that Github Firmware Source Code is still 3.33.
Can you upload the latest one, please?!
Bonjour avec vesc 6.4 quelles sont les valeurs maximales applicables au courant du moteur, au courant de la batterie et au courant maxi?
Si je veux 2 vesc dans ma configuration, devrais-je compter la valeur × 2 ou l'ampère reste le même et gauche 50/50?
Merci d'avance pour vos réponses.
it says i need the latest firmware so i can program my Dual board. i have NO PROBLEM donating money but i cant until someone shows or tells me how to do it.
Edward Gryglaszewski
