Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
Investing in promissory notes can be a good way to earn steady returns, as they often offer higher interest rates than traditional savings accounts. However, they come with risks, especially if the borrower defaults. If you're looking for more information on reliable investment options, you can check out this resource for further insights: https://similarsites.co.uk/36vegas/. It’s important to carefully evaluate the creditworthiness of the issuer before making an investment decision.
