sudo apt update
sudo apt upgrade
sudo apt install build-essential openocd git libudev-dev qt-sdkNow install the gcc-arm-embedded toolchain (see this page for more details)
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppapress Y, enter, then
sudo apt update
sudo apt install gcc-arm-embeddednow add udev rules to use the stlink v2 programmer without beeing root
sudo udevadm triggerAt this point you should be able to clone the firmware from github, build it and upload it. Let's give it a try
cd vesc_firmware
makeby default this will build firmware for hardware version 6. To change the hardware version, open conf_general.h and change it to use the hardware version that you have. For example, for HW 4.12 it should look like this
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endifthere are also many other options that can be changed in conf_general.h. To rebuild the firmware after the changes, run
makenow connect the stlink v2 programmer, connect power from a lab power supply and try to upload the firmware
make uploadIt should say verified ok towards the end if everything went well.
VESC Tool
cd Downloads
sudo ./qt-unified-linux-x64-3.0.2-online.runfollow the instructions to finish the installation. You might also need the following packages:
git clone https://github.com/vedderb/vesc_tool.git vesc_toolIt is recommended to open the project file from Qt Creator (which you should have after the previous step) and build the project from there. Instructions for building the android version will be added later.
Comments
Join in
This step-by-step guide to setting up a VESC development environment on Ubuntu is incredibly valuable for makers and developers working with firmware and VESC Tool! Math AI Solver is perfect for crunching the technical calculations and equations needed for firmware optimization and hardware performance tuning, while AI Color Analysis helps design eye-catching, high-contrast color palettes for VESC Tool’s UI and development documentation to boost readability. We even used Kirkify AI to create lighthearted memes about the trials of setting up dev environments, sharing a laugh with fellow tech enthusiasts in the VESC community.
My heat pump recently stopped heating the house properly
Hi everyone! My heat pump recently stopped heating the house properly and it struggles to maintain a comfortable temperature. I’m looking for a reliable repair service that works with heat pumps. Any recommendations?
I had a similar problem with my heat pump last winter.
I had a similar problem with my heat pump last winter. I used https://midweststandards.com/heat-pump-repair/ and the technician fixed the issue quickly. The service was professional, and the system has been working perfectly ever since.
gaming
Multiple game options allow players to choose favorites and enjoy different styles of online gaming with ease and flexibility anytime
p999 download app || b9 game login || lucky 101 login || k1 game || pk 365 ||
Hello everyone, I tried
Hello everyone, I tried something recently that caught my eye in a casual mention and ended up spending more time than I expected. The start was simple Slot Madness — no confusing menus or long explanations — which made it feel relaxing rather than stressful. I rushed at first and didn’t enjoy it much, but once I slowed down and took my time, it became much more enjoyable. I didn’t get anything major from it, yet finishing in a calm and content mood felt like a nice little win here in Canada.
Casino for you
The modern pace of life doesn't always leave room for extended relaxation. Online games
Boomerang Casino allow you to control the length of your leisure time. A short session can serve as a short break between tasks, and can easily be extended if desired. This format is suitable for those who value flexibility and don't want to be tied to a rigid schedule.
1v1 LOL games invite you to
1v1 LOL games invite you to breathtaking confrontations where quick reflexes are your strongest weapon. Press the join button today to experience the feeling of dominating the leaderboard with your building and shooting skills!
creationsitewebmarrakech
Création de site web au Maroc : des solutions sur mesure
Notre agence web à Marrakech Maroc est experte dans la création de sites internet professionnels : site vitrine, e-commerce, blog, portail institutionnel ou marketplace. Grâce à notre équipe créative et technique, nous garantissons des sites :
Red City Web – Agence Web à Marrakech, Maroc
Vous cherchez une agence web au Maroc fiable pour accompagner vos projets digitaux ? Faites confiance à Red City Web, votre partenaire digital basé à Marrakech. Spécialisée dans la création de site web au Maroc, notre agence web à Marrakech propose des solutions sur mesure adaptées à tous les secteurs d’activité.
creation site web maroc
Pour la création site web, rendez-vous à la meilleure agence web à Marrakech, Maroc, cette dernière est la agence de communication et SEO à Marrakech, Maroc la plus expérimentée.
La création site web Maroc n’a jamais été plus simple, créer un site web d’une grande qualité.
Une création site web Maroc rapide et facile avec des professionnels. Visitez aussi création site web Marrakech.
IT LABS PRO est la meilleure société de services d'ingénierie informatique pour création site web, internet à Casablanca, Marrakech, Maroc. En vous déplaçant à son siège à Marrakech - Guéliz, vous allez créer la meilleure application de gestion : ManagePro, disponible à Casablanca, Marrakech, Maroc, et bénéficier des meilleurs services de étapes création de site web rentable Casablanca, Marrakech Maroc, applications de gestion web, sites web, logiciels de gestion.
application gestion
La recherche société maroc , est une étape cruciale pour les entrepreneurs, les investisseurs et les professionnels souhaitant s'impliquer dans le marché marocain. Que vous cherchiez recherche société ice, des entreprises enregistrées, des détails sur recherche société rc, Ou des contacts ICE au Maroc,recherche entreprise maroc simplifiez vos démarches grâce à nos outils de recherche spécialisés.
Le blog de taekwondo au maroc, marrakech.
mice morocco
MICE Marrakech Events Marrakech is a Moroccan DMC (Destination Management Company) & Travel Agency. Specialized in creation, design, development and organization of your meetings, conferences, conventions, incentive trips, seminars and congresses.
At MICE Marrakech, we go beyond the ordinary, curating unforgettable journeys that showcase the best of Morocco's cultural richness and natural wonders.
Pour vos voyages PRO, L’Agence MICE a marrakech au maroc, best events in morocco est la meilleur agence au maroc, The best DMC in Morocco, Marrakesh, casablanca. It’s Meetings, incentives, conferencing, exhibitions in Marrakesh, Morocco.
dmc morocco
Atlas Outdoor – DMC & agence voyage à Marrakech, Maroc
Atlas Outdoor est une DMC basée au Maroc, experte en hiking in Morocco, Sahara hiking tours, biking and skiing adventures Morocco, ainsi qu’en family-friendly travel et student group trips.
Nous proposons des private luxury holidays in Morocco incluant spa and relaxation holidays, yoga and meditation retreats, creative and therapeutic retreats, customizable wellness holidays et golf tours in Morocco.
En tant que DMC Morocco et MICE Marrakech, nous organisons aussi des MICE travel, événements corporate et team-building activities.
ecolodge morocco
Découvrez une expérience inoubliable au cœur du Haut Atlas avec Adazen Lodge, un véritable havre de paix pour les amoureux de nature et d’authenticité. Si vous recherchez un Ecolodge au Maroc où confort et tradition se rencontrent, notre établissement est l’adresse idéale. Plongez dans une aventure unique avec nos nombreuses activités en montagne, incluant la randonnée à Aït Bouguemez. Vivez un séjour nature au Maroc et profitez d’un cadre exceptionnel propice à la détente et à la découverte.
sanitaire casablanca
Duchapro – Équipements sanitaires & sanitaire design à Casablanca, Maroc
Duchapro est une société Casablancaise spécialisée dans la vente d’équipements sanitaires haut de gamme au Maroc.
Découvrez nos gammes de vasques design pour salle de bain, parfaites pour votre intérieur à Casablanca ou ailleurs au Maroc.
Nous proposons également des lavabos pratiques, adaptés aux besoins résidentiels et professionnels, disponibles partout au Maroc.
Dans notre showroom à Casablanca, explorez nos receveurs de douche haut de gamme, conçus pour durabilité et esthétique.
tours morocco
Découvrez les richesses culturelles du Maroc grâce à My Travel Tours Morocco, une agence de voyages au Maroc spécialisée dans l'organisation de circuits touristiques et voyages privés. Explorez nos itinéraires flexibles, que vous soyez intéressé par un circuit dans le désert marocain, un voyage de 3 jours depuis Marrakech, ou un séjour de 8 jours au Maroc.
auberge marrakech
Découvrez le charme du Haut Atlas marocain en séjournant dans un hôtel à Ouirgane ou une auberge à Imlil comme Ksar Shama, niché au cœur des montagnes. Pour les amateurs de randonnées à Ouirgane, de vélo VTT, de cours de cuisine ou de padel tennis, c’est l’adresse idéale. Profitez également d’un hôtel avec piscine et restaurant pour un séjour relaxant.
imprimerie marrakech
Depuis plus de 63 ans, El Watanya s’impose comme une référence incontournable dans le domaine de l’imprimerie au Maroc. Fondée en 1958 à Marrakech, l’entreprise a su allier savoir-faire traditionnel et technologies d’impression modernes pour offrir à ses clients des solutions de haute qualité, adaptées à tous leurs besoins professionnels.
carreaux ciment
Kraftsol est la référence marocaine en matière de carreaux de ciment haut de gamme, alliant savoir-faire artisanal et design contemporain. Depuis sa création, la marque s’est imposée comme un acteur incontournable dans l’univers de la décoration et de l’architecture intérieure, en proposant des solutions uniques pour les espaces résidentiels et professionnels.
Notre histoire
Chez Kraftsol, chaque projet est né d’un équilibre entre innovation et tradition. L’entreprise s’est donnée pour mission de redonner vie à l’art ancestral des carreaux de ciment marocains, tout en y intégrant une touche moderne et élégante.
tours morocco
Nos tours de Marrakech sont pensés comme une immersion culturelle totale. Entre les ruelles animées, les artisans du souk et les secrets de la vieille ville, chaque visite est conçue pour révéler la magie nocturne et l’âme authentique de Marrakech. Sami, natif du quartier de la place des épices, a grandi au cœur de la Médina. Fort d’une expérience dans l’événementiel et le marketing hôtelier, il comprend parfaitement les attentes des voyageurs d’aujourd’hui. Nico, Français passionné par le Maroc, a quant à lui choisi Marrakech après des années de voyages et de gestion de riads. Ensemble, ils ont créé BabNightTour pour partager leur amour de la ville et proposer des expériences hors du commun.
fleuriste marrakech
Le Maroc est une terre riche de diversité culturelle, où chaque région, tradition et croyance apporte sa propre touche de beauté et d’authenticité. Cette richesse se reflète également dans les célébrations de mariage, où les fleurs occupent une place de choix. Chez Hajar Fleurs, votre fleuriste à Marrakech, nous mettons en avant cette diversité à travers des décorations florales uniques et personnalisées, adaptées à chaque culture et religion.
Pour votre mariage juif, nous réalisons une décoration raffinée de la houppa, avec des compositions mêlant roses, orchidées, hortensias, pivoines et lysianthus. Nos experts vous accompagnent dans le choix des couleurs et des volumes pour créer une ambiance féerique et harmonieuse.
avocat marrakech
Le cabinet Mouatamid Law Firm est un cabinet d’avocats marocain à Marrakech, fondé en 2019 par Maître Mouatamid Ahmed, avocat inscrit au barreau de Marrakech. Ce cabinet pluridisciplinaire offre un accompagnement complet en droit des affaires, droit immobilier et notarial, droit financier et propriété industrielle. Structure moderne et dynamique, Mouatamid Law Firm se distingue par une approche en constante évolution. Le cabinet intègre régulièrement de nouveaux talents et élargit son réseau à l’international, afin d’assurer un service juridique adapté aux besoins d’une clientèle variée, nationale et étrangère.
transport marchandises
FAST COMMODITY SOLUTIONS MAROC est une entreprise marocaine spécialisée dans le transport de marchandises par voie routière, maritime et aérienne. Grâce à une expertise solide et une approche centrée sur le client, la société propose des solutions logistiques adaptées à chaque besoin, qu’il s’agisse d’une simple livraison ou d’un service personnalisé pour vos plis, colis ou palettes.
Les services de FAST COMMODITY SOLUTIONS MAROC couvrent l’ensemble des besoins en transport, au Maroc qu’à l’international.
shopping morocco
BedEx Maroc est votre destination incontournable pour une expérience shopping moderne et fluide au Maroc. Notre plateforme vous propose une vaste sélection de produits de qualité, soigneusement choisis pour répondre à tous vos besoins du quotidien. Grâce à un service de livraison rapide et sécurisé, BedEx vous permet de recevoir vos achats où que vous soyez dans le royaume.
Découvrez l’histoire et la vision de notre entreprise sur la page À propos de BedEx, où nous partageons notre passion pour l’innovation et la satisfaction client. Fondée avec la volonté de rendre le shopping en ligne plus accessible et plus agréable, notre équipe met tout en œuvre pour vous offrir un service à la hauteur de vos attentes.
agence immobilier
Goldmine Estate – Votre partenaire immobilier de confiance
Goldmine Estate est votre partenaire privilégié pour des services immobiliers haut de gamme, offrant une expérience moderne, personnalisée et adaptée à vos besoins au Maroc ou à l’international. La plateforme met l’accent sur l’excellence et accompagne ses clients à chaque étape de leur projet immobilier.
FNF boasts a 2D street-style
FNF boasts a 2D street-style graphic design, reminiscent of the golden age of Newgrounds games. Smooth movements combined with vibrant colors will keep you glued to the screen from the very first notes.
Paybis
If you're looking for a replacement for Poloniex, I recommend considering services that offer direct asset purchases, such as
https://paybis.com/blog/poloniex-alternative/. There's a trend in the USA toward using platforms that simplify KYC as much as possible and operate within the legal framework, which is critical for the security of your funds. In the USA, users are increasingly choosing transparent gateways over traditional exchanges with complex interfaces. My recommendation is to switch to solutions that support instant withdrawals to your personal wallet. This not only saves time but also gives you full control over your private keys. Experience shows that this approach is much more reliable in 2026, when regulations are becoming stricter and exchange requirements in the US and Europe are constantly growing.
Totally get that—it can be
Totally get that—it can be tricky at first. What I do is look for platforms with clear licenses and real reviews from users in Pakistan. 1win has worked well for me; I like that it’s easy to register, deposit, and they offer helpful guides for new players. I usually play smaller bets until I get the hang of the games, and I always keep track of my limits. The site also supports local payment options, which is super convenient. Following this method, I’ve avoided common mistakes and actually enjoy the experience without feeling stressed.
Great guide — especially the
Great guide — especially the notes about changing the HW version in
conf_general.h, that part trips up a lot of people. Also worth mentioning that on newer Ubuntu LTS versions (20.04/22.04), some packages may need minor tweaks, but overall the workflow still holds up well.After long debugging sessions and dependency battles, I usually take a short mental reset before flashing firmware again 😄 A quick balance-based game like eggy car actually helps me clear my head and come back more focused.
Thanks for the detailed walkthrough!
Free time
When comparing casino platforms, I normally check the variety of games offered, usability, and how clear the rules are regarding payments and bonuses. A good casino should also have responsive support in case issues arise. While browsing gaming forums, I saw Neospin Casino mentioned multiple times in discussions about reliable platforms. I first came across it in conversations where players in Australia exchange tips and opinions about different casinos. Many highlighted that clear conditions, stable gameplay, and a diverse game library are essential.
Determining whether an online
Determining whether an online gaming club is safe in Canada can be challenging, but Cowboys Casino seems like a solid choice. The platform is well structured, provides clear information about games and bonuses, and offers transparent payment methods. I’ve tried other sites before, but few felt as professional and secure. For Canadian players who value both usability and reliability, Cowboys Casino provides an excellent environment for online gaming.
Casino Simulation: Creating a Game with Random Outcomes
Hi everyone! I was thinking about creating a small project where random outcomes are used—kind of like a mini ‘slot machine’ or roulette simulation, but entirely for fun and learning.
Galactic Spin: Interstellar Slot Adventure
That’s a great idea for a fun learning project! You can use https://winwin-bet.so/ as inspiration for mechanics and random outcome generation. Building this will help you understand probability and create engaging visual simulations.
While waiting for the
While waiting for the software update, everyone can relax together with the game Drift Boss.
Games
For anyone searching for a reliable gaming club in Canada, I would suggest trying Slotier Casino. I recently started playing there, and I was impressed by the extensive selection of slot games and table games. The platform is user-friendly, and the security measures gave me peace of mind while playing. Bonuses are fair and easy to claim, which really enhances the overall experience. If you want a balanced mix of fun, variety, and reliability, this is a solid choice in Canada.
Broker Features for Beginner Traders
Beginners might want to consider the https://roboforex.com/ platform. It offers a fairly intuitive interface and access to basic functions without being overly cluttered. Users can explore the service's structure, familiarize themselves with the tools, and gradually become comfortable with trading. This format reduces the likelihood of errors at the start and helps them feel more confident. Furthermore, gradually familiarizing themselves with the features helps them better understand the broker's operating system.
Wow, this is a really helpful
Wow, this is a really helpful guide! Setting up a dev environment can be tricky. Reminds me of trying to figure out how to run a fan game a while back. Anyone else remember the really early days of Fnaf? So simple, yet so effective! I bet this kind of setup would be great for game development, maybe even recreating some classic horror experiences. Thanks for sharing!
