sudo apt update
sudo apt upgrade
sudo apt install build-essential openocd git libudev-dev qt-sdkNow install the gcc-arm-embedded toolchain (see this page for more details)
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppapress Y, enter, then
sudo apt update
sudo apt install gcc-arm-embeddednow add udev rules to use the stlink v2 programmer without beeing root
sudo udevadm triggerAt this point you should be able to clone the firmware from github, build it and upload it. Let's give it a try
cd vesc_firmware
makeby default this will build firmware for hardware version 6. To change the hardware version, open conf_general.h and change it to use the hardware version that you have. For example, for HW 4.12 it should look like this
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endifthere are also many other options that can be changed in conf_general.h. To rebuild the firmware after the changes, run
makenow connect the stlink v2 programmer, connect power from a lab power supply and try to upload the firmware
make uploadIt should say verified ok towards the end if everything went well.
VESC Tool
cd Downloads
sudo ./qt-unified-linux-x64-3.0.2-online.runfollow the instructions to finish the installation. You might also need the following packages:
git clone https://github.com/vedderb/vesc_tool.git vesc_toolIt is recommended to open the project file from Qt Creator (which you should have after the previous step) and build the project from there. Instructions for building the android version will be added later.
Comments
Re: Best Video and Photo Editing App
If you want to take your video projects to the next level, the wink video editor provides easy-to-use features like creative templates, smooth transitions, and premium editing tools. It’s a practical resource for mobile creators who want polished, professional-quality results quickly and efficiently.
Ramp Xtreme
This is an excellent, detailed guide for anyone looking to step beyond the VESC Tool GUI and customize the firmware. The instructions for setting up the `gcc-arm-embedded` toolchain and handling different hardware versions (like 4.12) are crucial. I imagine this level of customization would be essential for pushing the limits of high-performance applications, maybe even optimizing the controllers used in something powerful like the *Ramp Xtreme*.
Meteor Mayhem in Your Hands: Dominate the Solar Smash Arena
Great guide on setting up the development environment! For those looking to take a break after coding, I recommend checking out Solar Smash. It’s a fun way to squeeze in some creativity after a focused session. If you’re curious about it, you can visit Solar Smash for more details. Happy coding!
This sounds like a really fun
This sounds like a really fun and exciting event for the Sacramento community! If you love creative block-based games and puzzles, you should definitely check out block blast. It’s a great way to bring healthy competition and creativity to a gaming gathering. I hope to see you all there!
This approach is very logical
This approach is very logical and has a clear investment strategy, standardizing Ubuntu 16.04 LTS as a foundation is a smart move to optimize the VESC Tool code production pipeline later. The process of updating the system and installing required packages is the first Friday Night Funkin' of the system, each flow and beat must be standardized to ensure liquidity for the dev environment. Just maintain this technical vision, ensure quality from the preparation step, and you will have a firm grasp of the maximum performance profit margin for the entire project, no need to worry much.
orbit kick
This guide is incredibly useful for anyone diving into VESC development. Getting the correct `gcc-arm-embedded` toolchain and Qt SDK configuration is always the biggest hurdle. Once the development environment is finally set up and the firmware uploaded, it feels like we've just completed the pre-flight checks before the main "orbit kick" maneuver!
The live betting interface is fast, reliable, and features real-time odds updates, which is crucial for UK users placing dynamic wagers during matches. The speed is impressive. Experience lightning-fast in-play action and quick cash-out options by joining the efficient live platform BoyleSports to place dynamic bets instantly and gain a real edge over the competition.
Look out for the "Drops & Wins
Look out for the "Drops & Wins" logo on games; those random prize drops can be massive.
You should definitely check out the Tournaments
You should definitely check out the "Tournaments" section on
https://bangercasino-online.com/bonuses/ Apart from standard deposit bonuses, they run regular slot races and leaderboards. Basically, you play specific games (like those from Pragmatic Play), and you earn points for every win. If you finish in the top positions, you win a share of a huge prize pool. It adds a lot of excitement because you can win the tournament prize on top of your regular slot winnings. It’s much more engaging than just standard play.
Just make sure to verify
Just make sure to verify your profile with your CNIC before requesting a big amount to make the process smoother.
I understand your concern because
I understand your concern because there are many scam sites, but
glory casino pk is reliable. I have made several withdrawals over the last few weeks, including one for 25,000 PKR, and it was processed without any issues. As long as you don't create multiple accounts and your phone number is verified, they pay out very quickly.
cool
If you are tired of routine and want vivid emotions, register at
website . It's not just a dating site, it's a window to the world. Here I met people from countries I had only heard of before. It's a really cool experience to communicate with foreigners. If you are open to the world and looking for a partner abroad, there is no better place. Try it, it's addictive!
The variety of reload bonuses
The variety of reload bonuses available at Lukki Casino provides continuous value for consistent players who want to get the most out of every deposit they make in Canada. Secure extra playtime by checking out their daily promotions and ensure your bankroll stays healthy while you explore the latest high-RTP releases from world-class developers.
This site stands out as a
This site stands out as a comfortable option for players in Canada. Spending time on slots garden felt straightforward and welcoming, without feeling overwhelming. It’s a nice recommendation for those who enjoy a simple and well-organized online casino setting.
