sudo apt update
sudo apt upgrade
sudo apt install build-essential openocd git libudev-dev qt-sdkNow install the gcc-arm-embedded toolchain (see this page for more details)
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppapress Y, enter, then
sudo apt update
sudo apt install gcc-arm-embeddednow add udev rules to use the stlink v2 programmer without beeing root
sudo udevadm triggerAt this point you should be able to clone the firmware from github, build it and upload it. Let's give it a try
cd vesc_firmware
makeby default this will build firmware for hardware version 6. To change the hardware version, open conf_general.h and change it to use the hardware version that you have. For example, for HW 4.12 it should look like this
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endifthere are also many other options that can be changed in conf_general.h. To rebuild the firmware after the changes, run
makenow connect the stlink v2 programmer, connect power from a lab power supply and try to upload the firmware
make uploadIt should say verified ok towards the end if everything went well.
VESC Tool
cd Downloads
sudo ./qt-unified-linux-x64-3.0.2-online.runfollow the instructions to finish the installation. You might also need the following packages:
git clone https://github.com/vedderb/vesc_tool.git vesc_toolIt is recommended to open the project file from Qt Creator (which you should have after the previous step) and build the project from there. Instructions for building the android version will be added later.
Comments
eggy car
Would love it if you could take it easy and play eggy car with me. Also, everyone can have fun here by playing the many games.
I sincerely hope that much
I sincerely hope that much more content of this kind will be released. I appreciate you giving me access to your information. I bookmarked your page because it had some really helpful information. A popular game that many people love is: tiny fishing
Wacky flip
I genuinely value your blog post. You have authentically delivered an enlightening and captivating blog content to all readers. Wacky flip is also a great choice in this genre.
speed stars game
speed stars stands out because it’s all about rhythm, timing, and control. The feeling of building momentum as you press the keys in sync is so satisfying. Every race feels like a challenge to master your own consistency. Whether I’m running hurdles, relays, or sprints, the gameplay stays smooth and responsive. It’s simple to learn but takes skill to truly master!
Re: Best Video and Photo Editing App
If you want to take your video projects to the next level, the wink video editor provides easy-to-use features like creative templates, smooth transitions, and premium editing tools. It’s a practical resource for mobile creators who want polished, professional-quality results quickly and efficiently.
Ramp Xtreme
This is an excellent, detailed guide for anyone looking to step beyond the VESC Tool GUI and customize the firmware. The instructions for setting up the `gcc-arm-embedded` toolchain and handling different hardware versions (like 4.12) are crucial. I imagine this level of customization would be essential for pushing the limits of high-performance applications, maybe even optimizing the controllers used in something powerful like the *Ramp Xtreme*.
Meteor Mayhem in Your Hands: Dominate the Solar Smash Arena
Great guide on setting up the development environment! For those looking to take a break after coding, I recommend checking out Solar Smash. It’s a fun way to squeeze in some creativity after a focused session. If you’re curious about it, you can visit Solar Smash for more details. Happy coding!
This sounds like a really fun
This sounds like a really fun and exciting event for the Sacramento community! If you love creative block-based games and puzzles, you should definitely check out block blast. It’s a great way to bring healthy competition and creativity to a gaming gathering. I hope to see you all there!
This approach is very logical
This approach is very logical and has a clear investment strategy, standardizing Ubuntu 16.04 LTS as a foundation is a smart move to optimize the VESC Tool code production pipeline later. The process of updating the system and installing required packages is the first Friday Night Funkin' of the system, each flow and beat must be standardized to ensure liquidity for the dev environment. Just maintain this technical vision, ensure quality from the preparation step, and you will have a firm grasp of the maximum performance profit margin for the entire project, no need to worry much.
orbit kick
This guide is incredibly useful for anyone diving into VESC development. Getting the correct `gcc-arm-embedded` toolchain and Qt SDK configuration is always the biggest hurdle. Once the development environment is finally set up and the firmware uploaded, it feels like we've just completed the pre-flight checks before the main "orbit kick" maneuver!
The live betting interface is fast, reliable, and features real-time odds updates, which is crucial for UK users placing dynamic wagers during matches. The speed is impressive. Experience lightning-fast in-play action and quick cash-out options by joining the efficient live platform BoyleSports to place dynamic bets instantly and gain a real edge over the competition.
Look out for the "Drops & Wins
Look out for the "Drops & Wins" logo on games; those random prize drops can be massive.
You should definitely check out the Tournaments
You should definitely check out the "Tournaments" section on
https://bangercasino-online.com/bonuses/ Apart from standard deposit bonuses, they run regular slot races and leaderboards. Basically, you play specific games (like those from Pragmatic Play), and you earn points for every win. If you finish in the top positions, you win a share of a huge prize pool. It adds a lot of excitement because you can win the tournament prize on top of your regular slot winnings. It’s much more engaging than just standard play.
Just make sure to verify
Just make sure to verify your profile with your CNIC before requesting a big amount to make the process smoother.
I understand your concern because
I understand your concern because there are many scam sites, but
glory casino pk is reliable. I have made several withdrawals over the last few weeks, including one for 25,000 PKR, and it was processed without any issues. As long as you don't create multiple accounts and your phone number is verified, they pay out very quickly.
cool
If you are tired of routine and want vivid emotions, register at
website . It's not just a dating site, it's a window to the world. Here I met people from countries I had only heard of before. It's a really cool experience to communicate with foreigners. If you are open to the world and looking for a partner abroad, there is no better place. Try it, it's addictive!
The variety of reload bonuses
The variety of reload bonuses available at Lukki Casino provides continuous value for consistent players who want to get the most out of every deposit they make in Canada. Secure extra playtime by checking out their daily promotions and ensure your bankroll stays healthy while you explore the latest high-RTP releases from world-class developers.
This site stands out as a
This site stands out as a comfortable option for players in Canada. Spending time on slots garden felt straightforward and welcoming, without feeling overwhelming. It’s a nice recommendation for those who enjoy a simple and well-organized online casino setting.
Thank you for sharing the
Thank you for sharing the guide on setting up a development environment on Ubuntu. This is very helpful for anyone who wants to build firmware and VESC Tools from source. I found that installing udev rules and selecting the correct HW_VERSION in conf_general.h to be crucial steps to avoid errors later.
retro bowl is a fun American football simulation game
cool
Sri Lanka is an incredible place, but there is one caveat: due to the intense heat during the day, you often have to stay indoors with the air conditioning on. To avoid going crazy from boredom within four walls, I found a cool pastime for myself. I go to
https://1xbetsrilanka.com/1xbet-app/ and time flies by unnoticed. It's the perfect way to add a little excitement to the slow island life. The game is simple, instantly addictive, and gives you a lot of emotions that are sometimes so lacking here. I recommend giving it a try!
The convenience of having
The convenience of having a fully functional casino in one's pocket is now a reality for players across the UK. Through https://apps4gambling.com/ users can explore a vetted list of the most reliable gambling apps that bring the excitement of the casino floor to mobile devices. This resource ensures that enthusiasts can easily find applications offering secure payment methods and a vast selection of games, allowing them to start playing wherever they are with total confidence in the software's integrity.
Game
Traffic Jam 3D is an engaging racing game in which players are tasked with maneuvering vehicles stacked vertically, averting collisions and overcoming obstacles across progressively more difficult levels, delivering an exciting and entertaining experience.
Why settle for less when the
Why settle for less when the best is available? Crown Casino offers an all-in-one gaming destination featuring live dealers, massive jackpots, and classic table games. Players can head to Crown Casino Melbourne to explore the vast selection. It serves as a comprehensive hub for every type of Aussie punter. From a quick spin to a strategic hand of Blackjack, everything is just a click away.
Yggdrasil pokies AU
Hello. With Yggdrasil pokies AU, you can definitely forget about everything else in the world. I like Australian casinos because they are very well designed and, most importantly, they can guarantee 100% protection of your personal data, which is very important because there can be a lot of scammers out there, and it is important to approach such a choice wisely.
Коли мова йде про азартні
Коли мова йде про азартні ігри, важливо орієнтуватися на легальні та безпечні майданчики з підтвердженою ліцензією. Одним із таких прикладів є ігровий майданчик Beton - офіційне казино, яке працює під українським законодавством і має ліцензію КРАІЛ для азартних розваг, що гарантує відповідальну гру, захист даних та прозорі правила участі у ставках.
British players are loving
British players are loving the chance to spin for massive rewards! Amazon site is famous for its generous welcome offers that keep the excitement high. Head over to Amazon Slots to see what prizes are waiting to be claimed today. From free spins on UK favorites like Starburst to big cash wins, it is the ultimate destination for slot lovers. It is time to take a spin.
Don't waste your time on
Don't waste your time on foreign websites with inconvenient currencies.
Fallsview Casino is completely tailored to Canada. Everything is in loonies and toonies, Interac support, and bonuses in our bucks. I've been playing here for three weeks now, and the payouts are coming in clearly. If you're looking for a stable casino with a good reputation, this is it!
love tester
Ah, Ubuntu and the joys of development environments! I remember wrestling with dependencies way back when. System updates, always the first hurdle, right? Setting up a space for VESC firmware, sounds specialized but familiar. Just like that time I needed specific libraries for a quirky image processing project. My initial setup attempts led to a cascade of errors. It felt like the computer was actively resisting progress. Love Tester Then, after much searching and tweaking, everything clicked into place.
agatha harkness coat
Such an interesting article here.I was searching for something like that for quite a long time and at last I have found it here.
For regular play within the
For regular play within the UK, I would recommend focusing on comfort and long-term reliability. Lottomart Casino offers a calm and user-friendly environment that suits ongoing gaming. Players in the UK often appreciate platforms that don’t overwhelm with unnecessary features but instead provide clear navigation and fair conditions. This kind of balance helps ensure a positive experience over time.
Комісії при звичайних
Комісії при звичайних переказах з картки просто зʼїдали значну частину мого бюджету тому я активно шукав альтернативу. Саме це перевірене біткоїн казино дозволило мені назавжди забути про втрати на транзакціях і зосередитися виключно на самому процесі гри. Я легко подвоїв свій стартовий депозит у лайткоїні всього за один вечір і отримав усю суму до останньої копійки без жодних прихованих зборів. Використовуй усі переваги децентралізації для свого швидкого збагачення.
resize image
This is a solid, step-by-step guide for setting up the VESC development environment on Ubuntu. It clearly outlines the necessary packages, from `build-essential` to the `qt-sdk`. The instructions are easy to follow, but perhaps for the final VESC Tool documentation, they will need to properly resize image assets to maintain a clean, professional look across different screen sizes.
we 999 apk
The success of the we 999 game 2026 can be attributed to its balance between simplicity and excitement. Many players appreciate that they do not need advanced gaming skills to start, yet the game still offers enough challenge to stay interesting.
hello
The sudo apt update command is just the start. Installing the gcc-arm-embedded toolchain and setting up udev rules feels like a tech puzzle Nano Banana
Sitting at the beach and having
Sitting at the beach and having a punt is the ultimate way to relax during our summer. The mobile optimization of Level Up casino AUS allows me to play flawlessly on 4G networks without eating up all my data. I have never experienced a crash or a glitched spin while playing away from my home WiFi. Reliable mobile performance is a must for the Australian lifestyle.
shape cropper
This is a comprehensive breakdown for getting the VESC environment running! The detailed steps for setting up the `gcc-arm-embedded` toolchain and udev rules are crucial. Since the VESC Tool is built with Qt, I wonder if future versions will include more advanced data analysis features. Maybe something like a specialized "shape cropper" for isolating complex waveform segments would be useful for diagnostics.
cool
Innovation is key to staying ahead in such a competitive market. I really appreciate seeing a forward-thinking approach that doesn't sacrifice data security for flashy features. This reminds me a lot of the strategy sessions I’ve followed through Aspers Casino , which consistently show how a well-managed platform can spark motivation and fresh thinking. Truly inspiring stuff for the modern industry!
Anomalous Coffee Machine
The
Anomalous Coffee Machine is a scary and interesting horror story that will have you on the edge of your seat. To get over your concerns and find out what the coffee machine is hiding, you need to be patient and pay close attention.
Leave a comment about your
Leave a comment about your favorite car in Drift Hunters and your record score!
Re: gaming
Attractive bonuses and simple gameplay make this app appealing for beginners and experienced players seeking fun real rewards online today 82 Lottery Game || Sikkim Game Register Link || 51 Game Login ||
Re: gaming
This platform offers entertainment and earning together making gaming more exciting and meaningful for modern online mobile game players everywhere Sikkim Game Login || The Lottery 7 Login Game || Sikkim Game APK ||
Re: gaming
User friendly layout helps players find games easily and start playing within minutes without unnecessary steps or confusion issues ever
66 Lottery Game || The Lottery 7 Invite Code || 51 Game Login ||
Embarking on Ubuntu
Embarking on Ubuntu adventures for VESC, eh? Updating, installing, cloning, making... feels like a developer's dance! Dealing with hardware versions is always a quirky adventure, it seems. Once, while setting up a Raspberry Pi for a robot project, I spent hours troubleshooting a seemingly simple hardware compatibility issue. The frustration was real, like navigating a maze designed by drift hunters. Sharing is caring!
This guide is super helpful
This guide is super helpful for setting up a dev environment on Ubuntu! I remember struggling with this when I first started. It's way easier now thanks to guides like these. Reminds me of the game Monkey Mart, you know, building your own little shop? I found a place to play it for free: Monkey Mart. Anyway, thanks for the clear instructions!
Hi! I installed films for my
Hi! I installed films for my commercial space to improve security and aesthetics. I ordered from https://www.tintfit.com/ in the UK, and I must say they did an excellent job. I first consulted with them on which films would be suitable for the office to control light and focus on security. They offered the perfect options — protective films that block strong sunlight and provide privacy. They installed it quickly, and now the office looks stylish and, most importantly, secure. Highly recommend them if you want something quality!
Join in
This step-by-step guide to setting up a VESC development environment on Ubuntu is incredibly valuable for makers and developers working with firmware and VESC Tool! Math AI Solver is perfect for crunching the technical calculations and equations needed for firmware optimization and hardware performance tuning, while AI Color Analysis helps design eye-catching, high-contrast color palettes for VESC Tool’s UI and development documentation to boost readability. We even used Kirkify AI to create lighthearted memes about the trials of setting up dev environments, sharing a laugh with fellow tech enthusiasts in the VESC community.
My heat pump recently stopped heating the house properly
Hi everyone! My heat pump recently stopped heating the house properly and it struggles to maintain a comfortable temperature. I’m looking for a reliable repair service that works with heat pumps. Any recommendations?
I had a similar problem with my heat pump last winter.
I had a similar problem with my heat pump last winter. I used https://midweststandards.com/heat-pump-repair/ and the technician fixed the issue quickly. The service was professional, and the system has been working perfectly ever since.
gaming
Multiple game options allow players to choose favorites and enjoy different styles of online gaming with ease and flexibility anytime
p999 download app || b9 game login || lucky 101 login || k1 game || pk 365 ||
Hello everyone, I tried
Hello everyone, I tried something recently that caught my eye in a casual mention and ended up spending more time than I expected. The start was simple Slot Madness — no confusing menus or long explanations — which made it feel relaxing rather than stressful. I rushed at first and didn’t enjoy it much, but once I slowed down and took my time, it became much more enjoyable. I didn’t get anything major from it, yet finishing in a calm and content mood felt like a nice little win here in Canada.
