Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
Has anyone had trouble with package dependencies on newer Ubuntu versions following this guide? I did on 20.04; had to manually install some older libraries and fiddle with symlinks to get everything compiling correctly. Anyone else run into similar issues? I've given up and just play Basket Random when it is tough!
Setting up a development environment for VESC firmware and VESC Tool on Ubuntu 16.04 and later can seem a bit daunting, but it’s pretty straightforward once you break it down.
N.G.-- Sydney food truck
Alright, buckle up buttercups, let's dive in. Ever wrestle with getting your coding cave just right? Setting up a dev environment can be a real headache, true story. Ubuntu 16.04 and beyond, eh? Sounds like a specific beast to tame. LTS releases... long-term support, gotta love that stability, allegedly. Reminds me of the time I spent a whole afternoon battling with Python dependencies trying to get a machine learning model to play Slither io, eventually I used Docker to circumvent the headaches.
This is a really great blog and I appreciate how you put everything together in such an organized way. It’s not easy to find content that’s both informative and enjoyable to read, but you’ve done it perfectly. Thanks a lot for posting this! By the way, you should also check this out https://gbapps.net/gbwhatsapp-apk-dl/.
MRSupernova
Monkey Mart: The Ultimate Gaming Marketplace Experience
Cat Mart
Step Into The Future of Gaming Commerce
Enter the world of Monkey Mart, where gaming meets innovation. We've created a cutting-edge marketplace that's transforming how gamers trade and connect globally.
Exclusive Features That Set Us Apart
Discover what makes us special:
  • Lightning-fast transactions
  • Live market analytics
  • Premium trading tools
  • Streamlined interface
  • Expert support team
  • [Image 3: https://i.ytimg.com/vi/TFGp_nD3UkU/maxresdefault.jpg] Caption: Immersive Trading Environment
    The Monkey Mart Difference
    Our Monkey Mart ecosystem offers: Monkey Mart Game
  • Dynamic pricing algorithms
  • Elite seller verification
  • Instant payment solutions
  • Vibrant trading community
  • Continuous platform upgrades
Effortless Trading Experience
At Monkey Mart, we enhance your journey with:
  • Smart search technology
  • One-click listings
  • Advanced filtering options
  • Multiple payment methods
  • Real-time transaction tracking
Unmatched Security
Trust in our robust protection:
  • Military-grade encryption
  • Biometric authentication
  • Intelligent fraud detection
  • Secure escrow system
  • Regular security updates
Community Benefits
Join the Monkey Mart revolution and receive:
  • VIP trading events
  • Premium market access
  • Loyalty rewards
  • Trading tournaments
  • Early feature access
  • Experience the next level of gaming commerce at monkeymart.one. Join the elite community of traders who trust Monkey Mart for their gaming assets.
    Quick Start Guide
    Start your Monkey Mart journey:
  • Instant registration
  • Quick verification
  • Immediate trading access
  • See why professional traders choose Monkey Mart for their gaming transactions. Visit monkeymart.one and elevate your trading experience today. Monkey Design
Using a do my assignment NZ service connects students with experts who know local academic standards. Assignments are carefully researched, structured, and tailored to requirements, ensuring clarity and quality. Students not only get better grades but also learn from well-written examples that strengthen their own writing skills. With expert support, learners can focus on other priorities while still excelling in coursework.
This is a really helpful guide, thanks for putting it together! I've been struggling to get my environment set up correctly, especially with some of the dependencies. I found a random video online that mentioned something about a labubu clicker to help with repetitive tasks during setup, but I wasn't sure if it was relevant. This guide seems much more straightforward and complete.
Great walkthrough! Setting up a development environment on Ubuntu can feel a bit overwhelming at first, but once everything is in Lakeside Park Roofing place, it makes coding so much smoother. I like how Ubuntu keeps things flexible for different stacks.
OliviaNapier's picture
Alright, diving headfirst into Ubuntu setup, eh? I remember wrestling with similar dependency demons! Setting up a dev environment can feel like navigating a jungle sometimes. It's all about getting those essential packages in line. We're talking system updates, build tools, and ARM toolchains. Funny enough, I spent an entire afternoon once struggling to get OpenOCD to play nice with my hardware. Remember that time? The error messages were cryptic, the forum threads endless. I am the Block Breaker, now i wanna share it.
kenvin roll's picture
In Sprunki Phase 3, drag-and-drop controls make creating eerie soundscapes simple, as players mix haunting loops with grotesque characters, triggering animations that transform cheerful tracks into unsettling compositions filled with creepy atmosphere.
Sprunki Phase 3 offers new challenges, allowing players to explore a vibrant and mysterious world.
This article explained it so well. I always wondered why certain videos blow up overnight—turns out summarize youtube video AI plays a huge role in that. https://ytbsummarizer.ai/
MRSupernova
This blog post is both informative and inspiring. I learned so much in such a short time, and I truly appreciate the clarity of your writing. Thank you for taking the time to help your readers like me. By the way you should also check this out: https://gbdownload.io/
MRSupernova
Awesome read! Tattoo AI helped me visualize a sleeve idea I’ve had for years. Now I actually feel ready to get it inked. https://getattoos.com/
MRSupernova
If Incredibox and a haunted arcade game had a baby, it’d be Sprunki Phase 3. Equal parts catchy and why is that avatar staring into my soul?
MRSupernova
As a broke student, I couldn’t justify paying for Spotify Premium—until I found a Spotify Premium MOD that gives all the premium perks for free. No more annoying ads during study sessions! If you’re on a tight budget, this is a lifesaver.
MRSupernova
Did you know that changing your wallpaper can boost productivity? Instead of using stock images, I used a Wallpaper AI Generator to create a minimalist, focus-enhancing background. The customization options are endless, and it’s completely free. A small change that made a big difference for me!
MRSupernova
Great guide on setting up a development environment on Ubuntu 16.04 and later LTS releases! You might also add tips for using apt-fast to speed up package installs and suggest lightweight IDEs like VS Code or Geany. For debugging, htop and ncdu are super helpful. Also, a fun break tool: wordle unlimited for brain refreshes. Consider mentioning containerization with Docker for consistent builds across teams.
If you’re looking for durable and stylish options, Canada offers a range of stores and online retailers specializing in women’s leather purses. Brands like FamilyLeatherOutlet and local boutiques provide genuine leather purses crafted for both elegance and practicality. Look for features like multiple compartments, secure closures, and adjustable straps for versatility. When choosing, consider size, style, and durability to ensure your purse meets daily needs while remaining a timeless accessory. Investing in a well-made leather purse ensures long-lasting quality and classic style suitable for any occasion.
On a rainy day in Vancouver, I didn’t feel like heading outside, so I opened my laptop and ended up trying Yabby Casino. The first thing I noticed was how smooth everything worked, even when switching between different games. They really put out a lot of promotions—welcome packages, weekly rewards, and free spins. It feels like there’s always something happening. In Canada, where the weather isn’t always great, I think sites like this are popular because you can play from the couch. I’ve stuck with it because it’s easy to use and offers enough variety so it never feels repetitive.
Reading this blog was an absolute pleasure. It’s informative, easy to follow, and gave me exactly the answers I was looking for. Thank you for taking the time to create such valuable content for your readers. Please try also GB WhatsApp Apk download
MRSupernova
Learning a language with YouTube videos? A YouTube AI summarizer helps by breaking down lessons into key phrases and vocabulary lists. Makes reviewing so much easier—try it!
MRSupernova
sprunki mods's picture
In its fast-paced 3D endless runner Slope Run, participants control a bright ball as it rolls across an endless track that includes turns, gaps, and slopes. The objective is straightforward: avoid falling off the edge and accumulate points by surviving as long as possible.There are no objectives or tasks in Ragdoll Playground, so it a sandbox game. It's just free-form exploration and imaginative thinking. Will you like to create untouchable fortresses, aircraft, submarines, etc.? Feel free to try anything you want in Ragdoll Playground.
Experience the thrill of
eggy car 2! With its engaging gameplay and stunning visuals, this game will keep you entertained for hours. Race through exciting levels and discover hidden treasures along the way!
io games are a genre of fast-paced, browser-based multiplayer games that became popular for their simplicity, accessibility, and instant action.
Castle App delivers fast video downloads. You can save large files quickly without delays, allowing you to enjoy your favorite movies or shows immediately after downloading them onto your device.
It supports multilingual subtitles for a global audience. Choose your preferred language, customize font settings, and enjoy content with subtitles that enhance understanding and accessibility for every viewer.
Ubuntu dev environments, eh? Funny, I remember wrestling with getting all the right bits aligned just so. Initially it can feel like navigating a maze. Getting the dependencies right is crucial, or things just break in spectacular fashion. Slope Unblocked memories flood back, almost the same level of frustration at times, haha! One time, I was trying to compile a custom kernel module, and I spent hours fighting mismatched headers. Talk about pulling your hair out! Took me ages to figure out I was using the wrong kernel version.
<p data-end="1772" data-start="1465">Main har din <a href="http://apkrocket.net/"><strong data-end="1508" data-start="1495">77cb game</strong></a> khelta hoon, aur mujhe har baar kuch naya seekhne ko milta hai. Yeh platform beginner-friendly hai aur rewards bhi genuine milte hain. Interface smooth hai aur customer service helpful. Jo log fun aur thrill chahte hain unhe <strong data-end="1747" data-start="1734">77cb game</strong> zaroor dekhna chahiye.</p>
http://apkrocket.net/" khelta hoon, aur mujhe har baar kuch naya seekhne ko milta hai. Yeh platform beginner-friendly hai aur rewards bhi genuine milte hain. Interface smooth hai aur customer service helpful. Jo log fun aur thrill chahte hain unhe <strong data-end="1747" data-start="1734">77cb game</strong> zaroor dekhna chahiye.</p>
If anyone’s struggling with business studies, I highly recommend New Assignment Help Australia. Their Business Assignment Help is detailed, on time, and easy to understand. I’ve tried other sites before, but none matched their quality and reliability.
To thrive in steal a brainrot, players should implement effective strategies. First, focus on resource management by investing initial funds in Brainrots that provide the best returns, building a solid income before expanding. When raiding, target weaker opponents to maximize gains and time your attacks for when they are most vulnerable. Equally important is investing in defensive measures like locks and shields to safeguard your collection from theft. Forming temporary alliances with other players can also be beneficial, as collaboration offers mutual protection and shared resources. Lastly, maintaining adaptability is crucial; stay alert to the actions of other players and be ready to adjust your strategies to maintain an edge in this competitive landscape.
Sheffield here! I'd definitely start with BetWarts Casino - their welcome package is quite generous. Make sure to use their deposit limit tools and explore different games. I've found their blackjack variations perfect for unwinding after work. The combination of fun and responsible features makes evenings much more enjoyable!
Hi there! I’ve spent quite a bit of time exploring different top betting sites in UAE, and I can definitely share some insights. The most important thing here is to choose platforms with proper licensing and secure payment methods. I personally prefer using international bookmakers like Betway and 1xBet - they provide good odds, quick payouts, and even Arabic-language support.
Sprunki has become popular because it’s more than just a game — it’s an outlet for imagination. You can create something funny, cool, or chaotic in just a few clicks.
While many sites offer betting, the live streaming service at 10bet really enhances the experience. Being able to watch the event I have a stake in, directly within their platform, is a game-changer. The stream quality is reliable, and it makes in-play betting so much more immersive and informed. It feels like having a sports bar in my pocket.
Would love it if you could take it easy and play eggy car with me. Also, everyone can have fun here by playing the many games.
I sincerely hope that much more content of this kind will be released. I appreciate you giving me access to your information. I bookmarked your page because it had some really helpful information. A popular game that many people love is: tiny fishing
I genuinely value your blog post. You have authentically delivered an enlightening and captivating blog content to all readers. Wacky flip is also a great choice in this genre.
speed stars stands out because it’s all about rhythm, timing, and control. The feeling of building momentum as you press the keys in sync is so satisfying. Every race feels like a challenge to master your own consistency. Whether I’m running hurdles, relays, or sprints, the gameplay stays smooth and responsive. It’s simple to learn but takes skill to truly master!
If you want to take your video projects to the next level, the wink video editor provides easy-to-use features like creative templates, smooth transitions, and premium editing tools. It’s a practical resource for mobile creators who want polished, professional-quality results quickly and efficiently.
For creators looking to enhance their mobile content, the https://winkapkz.com/ offers a variety of tools,
