Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
This is a really great blog and I appreciate how you put everything together in such an organized way. It’s not easy to find content that’s both informative and enjoyable to read, but you’ve done it perfectly. Thanks a lot for posting this! By the way, you should also check this out https://gbapps.net/gbwhatsapp-apk-dl/.
MRSupernova
