ADC Input Change
alivedom
ADC Input Change
Hi there
I have an VESC 4.12. As I soldered around on the Vesc it seems like the ADC1 is broken now. Im using mine for an diy Ebike so i have a hall throttle hooked up to it. The signal seems stuck on 2V even when i havent pluged in anything to it. So i checked the ADC2 which seems to be still working well. My problem is now that i cant use ADC2 for Current Control. Is there a way to exchange those signals in the software. It would be sad if i had to buy a new vesc just because of one broken ADC pin.
Thank you in advance
Dom
Last seen: 2 days 12 min ago
A quick update in app_adc.c should do the trick:
https://github.com/vedderb/bldc/blob/master/applications/app_adc.c
replace all ADC_IND_EXT with ADC_IND_EXT2
alternatively, you can change the hwconf file.
Hi Benjamin,
Can you update the Github Source Code with the latest version, please?
It seems to be stucked on the 3.33 firmware version.
alivedom
Aye
Thank you so much!
dsmx83
Unfortunately, I also have this problem.
I have modified the app_adc.c file, however, I don't know what to do next...
Would you be able to help me?
Thank you in advance.
dsmx83
andrecorreia
Me too. I'm having the same issue with the "FSESC 6.6". And I'm using the newest firmware 5.2.
It's a vesc with a single output. Only one motor. 60A Longboard Electrico FSESC 6.6 based upon VESC® 6 with Heat Sink e skateboard Accessories|Parts & Accessories| - AliExpress
I use it on my scooter. I only have a 3 wire throttle connected to ADC1. But ADC1 got broken after one day of use. It shows the ADC1 at full throttle even though there isn't anything connected to ADC1.
Now I cannot use my scooter because I can't find a way to set up  the vesc to replace the ADC1 signal with the ADC2 signal.
Anyone can help? I'm working on this for the last 8 days cannot find a solution.
Thanks,
edilger
Hi folks,
I had the same problem. ADC1 got stuck on 2V. It was still possible to get it higher by the throttle, but not lower. So I changed settings to Off <2V and On 3V. Using it on a 250W-bike it is not much issue having less range for the control. Another option is to use the LISP interpreter instead of a newly compiled version, which has to be done with any version update. There you just copy the values of ADC2 on the current control, using own filter for the ADC2 input. Of course disabling the control of ADC1 first via VESC-tool setup.
