Dual Motor Setup Wizard Not working 1.08
captclearleft
Hello, and thanks in advance.
I cannot get the dual motor setup to work with this new setup in 1.08.  (see link below for image)
The old setup wizard seemed real straight forward, but I have no idea what I am doing with this new format (and I cant find any documentation on the new 1.08 App Settings // Can-bus // dual motor...)
Here is an image of what I am talking about.  I have tried following the old instruction and applying them to this wizard ,but nothing seems to work.  Only one motor spins.
https://www.electric-skateboard.builders/t/vesc-tool-1-08-dual-motor-wizard-changed-not-working/90670
If someone can share how to step through this wizard for a dual motor setup, that would be great???
Thanks.
details:
pwm rc remote
(2) Vescs 4.12
Firmware 3.54
abrownmn
Bump.
My friend is having a similar issue I am trying to troubleshoot. The Wizard isn't even prompting the option for dual VESC.
jschro36
Bump.
Waiting to see if this gets fixed.
zmei116
is it fixed already?
ninjunc
Just entered this awesome world. Every tut I find online shows a different series of questions in the App Wizard for dual motors (multiple VESC). I am having the same problem as OP. Was there a fix or new tutorial?
buggermenot
Last seen: 1 week 6 days ago
For posterity: I was having a similar problem (the secondary/slave VESC was not getting the PPM forwarded to it.
Had to enable status sending and it worked like a charm.
