Dual Motor Setup Wizard Not working 1.08
captclearleft
Hello, and thanks in advance.
I cannot get the dual motor setup to work with this new setup in 1.08.  (see link below for image)
The old setup wizard seemed real straight forward, but I have no idea what I am doing with this new format (and I cant find any documentation on the new 1.08 App Settings // Can-bus // dual motor...)
Here is an image of what I am talking about.  I have tried following the old instruction and applying them to this wizard ,but nothing seems to work.  Only one motor spins.
https://www.electric-skateboard.builders/t/vesc-tool-1-08-dual-motor-wizard-changed-not-working/90670
If someone can share how to step through this wizard for a dual motor setup, that would be great???
Thanks.
details:
pwm rc remote
(2) Vescs 4.12
Firmware 3.54
abrownmn
Last seen: 6 years 2 weeks ago
Bump.
My friend is having a similar issue I am trying to troubleshoot. The Wizard isn't even prompting the option for dual VESC.
jschro36
Bump.
Waiting to see if this gets fixed.
zmei116
Last seen: 4 years 2 weeks ago
is it fixed already?
ninjunc
Just entered this awesome world. Every tut I find online shows a different series of questions in the App Wizard for dual motors (multiple VESC). I am having the same problem as OP. Was there a fix or new tutorial?
buggermenot
Last seen: 3 weeks 4 days ago
For posterity: I was having a similar problem (the secondary/slave VESC was not getting the PPM forwarded to it.
Had to enable status sending and it worked like a charm.
