Communication with Vesc Tools
9 posts / 0 new
faheemift
I am working on a project with Vesc. I can control motor with Vesc Tools. but now i need to create a GUI and from there i want to choose rpm/duty cycles ,etc. Do someone here know how can i communicate between my Gui code and Vesc Tools ?
Last seen: 8 months 3 days ago
a replacement gui out of vesctool?
faheemift
Hi, yes i want to create a gui which will communicate with vesctool for example if i want my motor to run at specific speed i want to take that argument from user on my gui and run motor through vesctool.
faheemiftikhar
CTSchorsch
Last seen: 1 year 3 days ago
There is no need to communicate over vesctool. You can communicate with the vesc directly via serial protocol
faheemift
Hi, Thanks for your answer. Suppose I have raspberry pi vesc and bldc motor. Do you have any advice for me on how to start controlling the motor without vesc tool? Because with vesc tool I can run the motor as fast I want. But when it comes to serial protocol, I have no idea how to start sending commands. Thanks again for your time.
Regards
Faheem
faheemiftikhar
CTSchorsch
There is an Arduino project you can use as starting point: https://github.com/SolidGeek/VescUart
But for the raspberry you have to write your own code, i think. Maybe there is a port somewhere... ask google
you can look at the vesctool code, too. it is not so difficult to build the messages for the vesc
faheemift
Thanks i am going to work on it.
faheemiftikhar
TheFallen
I've been using a modified version of PyVESC https://github.com/LiamBindle/PyVESC on my Raspberry Pi chatting to VESCs.
beatrixena
Last seen: 5 years 1 week ago
thanks for update
