Flipsky HC 200A VESC programming to eFoil motor
9 posts / 0 new
tylerclark
I have the Flipsky High Current FSESC 200A and a Flying Rodeo motor along with the Maytech waterproof remote control. I am having trouble programming the VESC. First off, I've been using the VESC tool for Mac v2.03 available from here.
Says the fireware is 4.2, Hw: 60
When I try to run the motor wizard upon connection, it appears to work. I configure the remote controller and that appears to work too. However, I get some stuttering when I barely hold down the trigger and it also isn't spinning at nearly the RPM it can operate (I know this because I have another Flier 400 ESC that I've used). So, how can I get the motor to go faster and how can I get it to not stutter and super low speeds?
VESC ID: 87
Motor current: 72.67 A
Motor R: 13.30
Motor L: 7.28
Motor Flux Linkage: 5.36
Temp Comp: False
Sensors: Sensorless
renaudbarbier
Last seen: 1 year 21 min ago
did you run it in bldc mode or FOC?
Last seen: 3 months 1 day ago
If you are using FOC, for low speed stuttering, reduce the Openloop ERPM in sensorless tab.
For the high speed, you might be hitting erpm limit. Post a video / screenshot of the realtime graph showing your problem.
jessbello
I have the same configuration as yours but with a motor flipsky 120kv 6000w.
My problem is similar when I reach 60% of remote acceleration the motor start to stutter and if I accelerate more the motor stop. When I measure I have only 50A on the motor but I should be able to go up to 120A.
Does someone have an idea what could be my issue.
My general motor setting is BLDC.
jessbello
jessbello
jessbello
A4D44A56-EFE3-471E-8522-0E1D6E9DFA5B.jpeg3387736A-73E0-4854-8561-472F54F051AF.jpegE2105FEC-8A7C-4C21-AE36-64988FD39425.jpeg047B9B2A-CA21-4199-845D-C8B8E515C179.jpeg
jessbello
okarbon
Hi Guys,
I got some problems with the same vesc, 5.1 firmwere.
When runing FOC mode -duty cycle no reverse with ppm vesc starting heating up, if I unplug ppm cable the heating stops frown
Very strange behaviour,I m sending youtube video for easyer explanation what is going on.
https://www.youtube.com/watch?v=zZySvn5wKx8&feature=youtu.be
Does anyone have similar problems? What can be the cause for the heating?
Best Regards!
Simon
