Flipsky HC 200A VESC programming to eFoil motor
9 posts / 0 new
tylerclark
I have the Flipsky High Current FSESC 200A and a Flying Rodeo motor along with the Maytech waterproof remote control. I am having trouble programming the VESC. First off, I've been using the VESC tool for Mac v2.03 available from here.
Says the fireware is 4.2, Hw: 60
When I try to run the motor wizard upon connection, it appears to work. I configure the remote controller and that appears to work too. However, I get some stuttering when I barely hold down the trigger and it also isn't spinning at nearly the RPM it can operate (I know this because I have another Flier 400 ESC that I've used). So, how can I get the motor to go faster and how can I get it to not stutter and super low speeds?
VESC ID: 87
Motor current: 72.67 A
Motor R: 13.30
Motor L: 7.28
Motor Flux Linkage: 5.36
Temp Comp: False
Sensors: Sensorless
renaudbarbier
Last seen: 12 months 4 days ago
did you run it in bldc mode or FOC?
Last seen: 3 months 16 hours ago
If you are using FOC, for low speed stuttering, reduce the Openloop ERPM in sensorless tab.
For the high speed, you might be hitting erpm limit. Post a video / screenshot of the realtime graph showing your problem.
jessbello
I have the same configuration as yours but with a motor flipsky 120kv 6000w.
My problem is similar when I reach 60% of remote acceleration the motor start to stutter and if I accelerate more the motor stop. When I measure I have only 50A on the motor but I should be able to go up to 120A.
Does someone have an idea what could be my issue.
My general motor setting is BLDC.
jessbello
jessbello
jessbello
A4D44A56-EFE3-471E-8522-0E1D6E9DFA5B.jpeg3387736A-73E0-4854-8561-472F54F051AF.jpegE2105FEC-8A7C-4C21-AE36-64988FD39425.jpeg047B9B2A-CA21-4199-845D-C8B8E515C179.jpeg
jessbello
okarbon
Hi Guys,
I got some problems with the same vesc, 5.1 firmwere.
When runing FOC mode -duty cycle no reverse with ppm vesc starting heating up, if I unplug ppm cable the heating stops frown
Very strange behaviour,I m sending youtube video for easyer explanation what is going on.
https://www.youtube.com/watch?v=zZySvn5wKx8&feature=youtu.be
Does anyone have similar problems? What can be the cause for the heating?
Best Regards!
Simon
