5phase Vesc based on 75/300
9 posts / 0 new
BartE
Me and my son are building a e-scooter with a 5 phase BLDC motors we have handy (25 poles). The idea is to build the driver based on the Vesc 75/300.
Can anybody predict how difficult it would be to change the Vesc firmware for 5 phases.
How compatible will that be with the Vesc tool?
All advises are very much appreciated.
PS : Some people likes to join building this thing. That makes the efforts smaller...
Just wondering why 5 phases, not 7 or 11?
pf26
Last seen: 2 months 23 hours ago
Why do you assume only to change "Vesc firmware" ?  It seems you first need change VESC hardware (to drive 5 phases instead 3). That means massive rework - not even sure that the chip in use has enough fast timers/PWM output to do it. Or maybe I am missing something..
BartE
Of course the hardware needs to be reworked. I did not mention this as I have a better idea what it takes to do that. And yes... I do underestimating mostly the time i spend to finish projects frown.
I hope to be inspired by the original design of the Vesc 75/300 to make the power routing well...
100 pin MCU from the same family offers 16 timers for PWM. Is I can understand from the schematics there are just 2 PWM's per phase needed.
I did not looked into the firmware source code what it should take to expand it to 5 phases. I hope to get a better idea how easy are difficult it is to fit this into the firmware from the people on this forum.
BartE
Vadicus : Might be an idea to make the number of phases modular.
Seems like rewinding into three phase would make way more sense.
BartE
How do you divide 25 poles in 3?
Pimousse
Could be wrong but you might need a beefier MCU with 5 ADC.
That will ask some rework on this side as well. Not an easy task I guess.
There is a chance you can run this motor using 3 out 5 phases with some code adjustments. If this is a purely educational project, introducing unnecessary complexity would make sense. However, if the goal is to make a viable product and time/money is not without a limit, it would be worthwhile to reconsider the motor selection. There is a reason 3 phase approach is pretty much standard in motor drives. There are some very specific use cases for more phases but a scooter is not one of them.
