Setting up a development environment on Ubuntu 16.04 and later LTS releases
Submitted by benjamin on Wed, 2018-01-24 10:16
sudo apt update
sudo apt upgrade
press Y, enter, then
sudo apt update
sudo udevadm trigger
cd vesc_firmware
make
	!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endif
make
make upload
VESC Tool
cd Downloads
Comments
For those struggling with essay writing, I’ve found an amazing website that provides exceptional writing services. Their professional writers are experienced in various academic fields and can produce essays that are both engaging and well-researched. This 99 papers.com service ensures that your essays are delivered on time and meet all your academic requirements. It’s a fantastic resource for students seeking reliable writing assistance.
However, standing out in a saturated market requires more than just creating great music. I found a service that could be a game-changer for those looking to make an impact on Beatport. https://promosoundgroup.net offers a specialized Beatport Top 100 promotion service that is tailored to elevate your track's visibility. Their approach combines targeted promotion with industry insights, ensuring your music reaches the right audience. By leveraging their services, you can increase your chances of making it into the coveted Top 100 and gaining the recognition you deserve.
Dive into the world of Unblocked Games 76 where every game is a new journey. Experience the luxury of premium gameplay, whether you’re playing with family, classmates, or on your own. Unblocked Games 76 transforms your free time into exhilarating adventures, combining passion and class in every session. Discover excitement like never before with Unblocked Games 76!
Here are many extremely attractive adventure and horror game titles that have been loved by many people around the world such as Skribbl io or five nights at freddy's. Coming to this version this time you will continue the adventure full of attraction and no less adventurous, you have to overcome great challenges.
