ADC Connector is very touchy
ebikerevolution
Hi there,
Relatively new DIY eBiker here. I'm providing current to my motor using a hall-sensing throttle on ADC (3 wire: 3.3V,GND,Signal). However, once everything is set up and written to the VESC, the connection between the throttle and VESC is very touchy. Any physical movement makes the motor spin up. This is a definite safety issue, so does anyone have an idea for a fix to this?
Best,
EBR
portnawake
Last seen: 6 years 2 weeks ago
Maybe you could adjust the ADC Min voltage so that the throttle only engages when purposefully turned.
Last seen: 9 hours 14 min ago
Did you tune the adc input to the range of the throttle? It does sounds like a bad connector or solder joint.
