ADC Connector is very touchy
ebikerevolution
Hi there,
Relatively new DIY eBiker here. I'm providing current to my motor using a hall-sensing throttle on ADC (3 wire: 3.3V,GND,Signal). However, once everything is set up and written to the VESC, the connection between the throttle and VESC is very touchy. Any physical movement makes the motor spin up. This is a definite safety issue, so does anyone have an idea for a fix to this?
Best,
EBR
portnawake
Maybe you could adjust the ADC Min voltage so that the throttle only engages when purposefully turned.
Did you tune the adc input to the range of the throttle? It does sounds like a bad connector or solder joint.
