How to communication with arduino on vesc via can
yuri12
Hello.
I wan to check the VESC CAN message with Arduino. When I connected Arduino uno and mcp2515 to the VESC CAN pin, I couldn't get any message. How can I read the message?
And after this is solved, I want to control VESC via CAN communication. Is there anything else I need to modify other than code modification?
Please help me!!!
olivierabristol
https://dongilc.gitbook.io/openrobot-inc/tutorials/control-with-can
https://electric-skateboard.builders/t/vesc-can-message-structure/98092/7
hello yuri, you will find all you need on this two links. Btw, pay attention to the MCP2515 you are using, mine has a 8Mhz oscillator so I had to double the working frequency to make it works. For example if you set 500 kHz on vesc and you have a 8 Mhz MCP2515, you shall  set the MCP 2515 @ 1000 kHz
Olivier
Craig_Gault
Last seen: 5 months 4 days ago
You can use the MCP2515 module and this library to communicate with the vesc over CAN bus.
https://github.com/craigg96/vesc_can_bus_arduino
CGault
