inconsistent behavior after motor control using FOC
alexantosh
Hello, I controlled a Brushless DC motor using FOC on vesc-tool 3.00. Firmware: 5.2, HD:60.
After i got the behavior i desired, I wrote the motor configuration, and saved the configuration file. From the vesc. When I run the motor when not attached to the VESC tool in a different session, I get different motor behavior.
When i connect it to the vesc tool to confirm. It gives different behavior even when i reload the saved motor configuration file. Why does this happen?
Do I need to check and re control the motor each time i need to run it?
How can i solve this? Thanks.
Could you please try the Beta Vesc-Tool and do a new detection. You can not use your old CFG with the new tool! You should not see different behavior when disconnected from VESC-Tool.
https://vesc-project.com/node/2859
