Stutter start
benha
Last seen: 5 years 1 week ago
Stutter start
Howdy!
I'm working on a project that uses a VESC to control a propeller on a dive propulsion vehicle. Normal controllers are hard to deploy so I'm using two switches with different resistors to create a low and high throttle setting in ADC mode.
When I start up, I get a quick stutter I'd like to massage out of the system. Video here:
https://youtu.be/H1j6QDoRWao
Anyone have suggestions for what's going on and how I can fix it?
-Ben
benha
FWIW, it seems this only happens in Duty Cycle mode.  When I switch it to Current I get smooth starts.
The video shows no stutter per se. A quick reverse move seems to be the way to detect the rotor position in sensorless mode. It's normal.
flyingbrike
flyingbrike's picture
My stottering went away when i activated HFI mode
Silent Revolution is NOW !
