How can I add watts data to solidgeek?
Fixitmoditbreakit
Hi guys
I've made a dyno to test electric motors,  well at the moment I'm testing the output of a converted alternator.  I'm using solidgeek code with arduino on the uart port and have erpm for converting torque in to hp but would like to add watts being used so I can work out the efficiency.  Any help would be much appreciated!  Here's a link to my YouTube video,  I've added the mechanical kw conversion to the code after this video
https://youtu.be/JPYTZSAWQqU
Fixitmoditbreakit
Forgot to add I'm using a flipsky 6.6 water cooled
You can use SolidGeek library as an example, look how other data is received and processed here:
https://github.com/RollingGecko/VescUartControl/blob/008f89efc916009d266...
For example:
values.ampHours = buffer_get_float32(message, 10000.0, &ind);
values.ampHoursCharged = buffer_get_float32(message, 10000.0, &ind);
Then you would modify the library to include new data from what VESC is sending.
Wh used, for example, are here:
https://github.com/vedderb/bldc/blob/be439a2a55ae5b1ba8cce8ad6b0da2d8046...
