FAULT_CODE_HIGH_OFFSET_CURRENT_SENSOR_3
11 posts / 0 new
TB_Poule
Hello everybody, I have had a problem for a few days with my VESC 6+ that I have been using since 2019 on a bike.
The red led is flashing and I have a fault code: FAULT_CODE_HIGH_OFFSET_CURRENT_SENSOR_3
Last week i did a firmware update, but i must have made a wrong manipulation when i reprogrammed the motor parameters in FOC mode? Could not find the solution to eliminate the problem !?
Can anyone help me? Sincerely, TB.
That means the current sensor on phase 3 must have failed. In VESC tool, go to Sample Data, select Current tab, hit "Samples now" and post the graph here.
TB_Poule
Hi, for the moment I cannot insert my image ...
TB_Poule
Sensors seem to be fine according to the graph. Can you go to the terminal and run these commands: 1) hw_status; 2) faults. Then post ouputs for both.
TB_Poule
on the graph it seems nevertheless that there is a little offset for I phase 3 ?
here is the result of the tests you ask me:
hw_status:
Firmware: 5.2
Hardware: 60
UUID: 2D 00 2D 00 16 47 37 33 38 33 32 38
Permanent NRF found: No
FOC Current Offsets: 2047 2047 3337
USB config events: 1
USB write timeouts: 0
Mempool mcconf now: 0 highest: 0 (max 9)
Mempool appconf now: 0 highest: 0 (max 2)
faults:
No faults registered since startup
fault:
Yes, your hw_status response shows that the sensor phase 3 is not good. The program is auto offsetting it too much: FOC Current Offsets: 2047 2047 3337
It's either disconnected or the amplifier is shot. I  would inspect it and measure voltages on the amplifier and compare it to voltages on a good sensor.
Another possibility, considering that you said this happened after fw update, is incorrect version of the fw is installed. Maybe sensor 3 is mapped to a different pin in the new firmware. Although unlikely, I would still double check. You might also want to reinstall the fw just in case something didn't write correctly, although, unlikely as well if the controller responds.
TB_Poule
You're right, when we analyze the programming we come to the same conclusion:
in terminal.c:
commands_printf ("FOC Current Offsets:% d% d% d", curr0_offset, curr1_offset, curr2_offset);
In mcpwm.c:
#ifdef HW_HAS_3_SHUNTS
curr2_offset = curr2_sum / curr_start_samples;
In mc_interface.c:
if (abs (curr2_offset - MIDDLE_ADC)> HW_MAX_CURRENT_OFFSET) { mc_interface_fault_stop (FAULT_CODE_HIGH_OFFSET_CURRENT_SENSOR_3,! is_motor_1, false);
in hw_axiom.h:
#define HW_MAX_CURRENT_OFFSET 620 // More than this offset (0.5 Vdc) trips the offset fault (likely a sensor disconnected)
I do not believe that the problem comes from the software, I have redone the programming several times ...
I will try to test the circuit ...
bayetan
Hello vadicus,
Should the current (Mean Filtered} for 3 phases read close to zero?  My Phase3 current is below zero and Phase1 and Phase2 are slight above 0.  I tried executing "foc_sensors_detect_apply" with 5 amps.  After some current was applied, I got the response no sensor found and changed to "senseless mode".  Was originally in "Encoder mode".  Can/Should I change the offset?
Thanks, Ben
bayetan
Hello vadicus,
I' not getting a fault but Should the current (Mean Filtered} for 3 phases read close to zero?  My Phase3 current is below zero and Phase1 and Phase2 are slight above 0.  I tried executing "foc_sensors_detect_apply" with 5 amps.  After some current was applied, I got the response no sensor found and changed to "senseless mode".  Was originally in "Encoder mode".  Can/Should I change the offset?
Thanks, Ben
Mohanangappan
Mohanangappan's picture
Last seen: 2 years 4 weeks ago
Screenshot (1).pngHi,
We are also facing same problem for the Fault in current sensor 1 and 3. The error screenshot attached for your reference. Kindly give the solution for this. what is problem and suggestions. . We checked sensor and FET side not short are there. Screenshot (4).png. We checked sensor and FET side not short are there.
Mohan
