A real Noob Question
donrecardo
Hi
I don't want to make a long board or scooter or such , I am actually hoping to use the  controller to run the motor on a gem stone faceting machine that I am building
I want to be able to set the speed  and maybe have it running at that speed for perhaps an hour at a time
My question is , can I use the PWM output from an arduino to set the speed on the controller or if not would a
servo tester output work ?. I cant see how that would be any different to an RC receiver output
I have a nextion touch display on the gem faceting machine which shows a slider on the screen , by sliding the slider the touch screen sends the new
value back to the arduino which I could then use to determine the PWM pulse ratio.  Is this a feasible way to control the VESC?
Sorry for the noob question but will all have to start not knowing much at the beginning
Don
danspratt
Using an arduino with the servo library will work just fine with the VESC, servo tester will too. I believe using the PID speed control setting will try to spin the motor at the same speed regardless of load.
donrecardo
Thanks for the reply Dan
