Need help to configure the regenerative brake ...
Loops
Hello all !
First, i'm sorry for my aproximative english.
I've build a E-mountainboard. The setup is :
- 2 SK8 6374 130KV (sensored)
- 2 FLIPSKY FSESC 6.6
- 12S Lipo
I will try to explain you my problem ...
All works perfectly ... I'm ridding, I've the throttle at 50% (for example). If i release the throttle, the board continue in 'free weels" ... But if i accelerate with a throttle less than before, 25% for example, the board will brake ...
Is there a way to brake only if i put the throttle in reverse ?
Thank you a lot for your help, i hope you can understand my problem.
JC
Do the standard setup and choose " Current no reverse with brakes" or "Current Hyst. reverse with brakes".
https://vesc-project.com/node/178
Loops
Thank you for your help.
The configuration in the ESC is "Current no reverse with brakes". I will try ASAP the other mode.
