sudo apt update
sudo apt upgrade
sudo apt install build-essential openocd git libudev-dev qt-sdkNow install the gcc-arm-embedded toolchain (see this page for more details)
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppapress Y, enter, then
sudo apt update
sudo apt install gcc-arm-embeddednow add udev rules to use the stlink v2 programmer without beeing root
sudo udevadm triggerAt this point you should be able to clone the firmware from github, build it and upload it. Let's give it a try
cd vesc_firmware
makeby default this will build firmware for hardware version 6. To change the hardware version, open conf_general.h and change it to use the hardware version that you have. For example, for HW 4.12 it should look like this
!defined(HW_VERSION_TP)
//#define HW_VERSION_40
//#define HW_VERSION_45
//#define HW_VERSION_48
//#define HW_VERSION_49
//#define HW_VERSION_60
//#define HW_VERSION_R2
//#define HW_VERSION_DAS_RS
//#define HW_VERSION_PALTA
//#define HW_VERSION_RH
//#define HW_VERSION_TP
#endifthere are also many other options that can be changed in conf_general.h. To rebuild the firmware after the changes, run
makenow connect the stlink v2 programmer, connect power from a lab power supply and try to upload the firmware
make uploadIt should say verified ok towards the end if everything went well.
VESC Tool
cd Downloads
sudo ./qt-unified-linux-x64-3.0.2-online.runfollow the instructions to finish the installation. You might also need the following packages:
git clone https://github.com/vedderb/vesc_tool.git vesc_toolIt is recommended to open the project file from Qt Creator (which you should have after the previous step) and build the project from there. Instructions for building the android version will be added later.
Comments
Was stuck indoors cause of a big storm outside, got curious about some adult fun. Wanted to see real people doing live stuff instead of boring clips. Checked out xxx live and wow, it’s got teens and mature women on free sex cams. You get live porn and chats, tons of options, and it’s all free to start watching right away. Made my day way better, loved the real vibes.
Setting up a development
Setting up a development environment on Ubuntu can be challenging, but following guides can simplify the process. Whether you're working on projects like firmware development or tools, having a clear procedure ensures efficiency. If you're into relaxing after some coding, try playing Snow Rider 3D. It's a fun, engaging game that'll refresh your mind between tasks. Remember, balancing work and leisure is essential for productivity.
omegle
Welcome to Omegle, where distance disappears and conversations flow freely. Our platform has revolutionized how people connect, creating a space where millions gather daily for meaningful interactions.
Permintaan Bantuan: Perubahan Nameserver Tidak Berhasil
Many of the students have been facing many difficulties to write their assignment that is submitted at the university.We have a team of a professional content writer,that is available 24 hours to help the students.We offer an online <a href="https://www.pavilion-tokyo.com/">PATRIOT88</a>
<a href="https://www.pavilion-tokyo.com/">slot dana terpercaya</a>
<a href="https://www.chumon-san-a.com/">Scatter Hitam</a>
<a href="https://www.chumon-san-a.com/">Patriot88</a>
<a href="https://www.chumon-san-a.com/">Situs Game Gacor</a>
<a href="https://gaihekitosou-hyouban.com/">SLOT DEPOSIT 10k</a>
<a href="https://gaihekitosou-hyouban.com/">Patriot88</a>
<a href="https://www.patriot-banyakvip.site/">Patriot88</a>
<a href="https://totalprestigecommunity.com/">Patriot88 Login</a>
<a href="https://www.neomwifi.net/">Patriot88 SLOT</a>
Re: Mya Matthews Nude
Welcome to PATRIOT88, where distance disappears and conversations flow freely slot dana terpercaya. Our platform has revolutionized how people connect, creating a space where millions gather daily for meaningful interactions. Setting up a development environment on Ubuntu can be challenging, but following guides can simplify the process. Whether you're working on projects like firmware development or tools, having a clear procedure ensures efficiency SLOT DEPOSIT 10k. If you're into relaxing after some coding, try playing PATRIOT88. It's a fun, engaging game that'll refresh your mind between tasks. Remember, balancing work and leisure is essential for productivity PATRIOT88 LOGIN
I miss the days of printing
I miss the days of printing Mapquest directions before road trips. Tried it again recently for fun—it still works like a charm!
sprunki mods
henry stickmin is a stickman that commits daring crimes and escapes with eccentric plots that are funny regardless of the result. Henry Stickmin's wild adventure games have captivated players worldwide.
Fnaf 1
Its use of minimal movement and static screens makes the horror hit even harder Fnaf.
Hey everyone, just getting
Hey everyone, just getting started with VESC development on Ubuntu 16.04 and newer? This guide is super helpful for setting up your environment. It walks you through the initial updates and package installations. Remember, a smooth setup is key to avoid roadblocks later. It's like the starting line of Slope Game, you need a good launch to conquer the course. Get your environment right, and the coding will flow!
Tubidy MP3
YouTube to MP3 - Convert your
Konverter YouTube ke MP3
This blog post is a fantastic
This blog post is a fantastic resource for setting up Ubuntu 16.04! As someone who manages IT tasks at AZ Sliding Fix commercial door repair Florida, I found your guide incredibly helpful. The step-by-step instructions for installation, configuration, and optimizing the system are clear and easy to follow. Your tips on partitioning and securing the installation have been particularly useful for ensuring our systems run smoothly and securely. Thank you for providing such detailed and practical advice. This post has made the setup process much simpler and more efficient for us!
Wordle Unlimited
Wordle Unlimited is an addictive word puzzle game you can play endlessly to challenge your vocabulary. Try to guess the hidden word in six attempts. Play now at https://wordleunlimited.click/ and improve your word skills!
This blog post is a fantastic resource for setting up Ubuntu 16.04! As someone who manages IT tasks at Atlas Door Repair's commercial door repair Florida, I found your guide incredibly helpful. The step-by-step instructions for installation, configuration, and optimizing the system are clear and easy to follow. Your tips on partitioning and securing the installation have been particularly useful for ensuring our systems run smoothly and securely. Thank you for providing such detailed and practical advice. This post has made the setup process much simpler and more efficient for us!
It’s not flashy, but it
hmm
When cloning the firmware
When cloning the firmware from GitHub, remember to adjust the `conf_general.h` file for your specific hardware version before running `make`. This step ensures that your build is compatible with your setup. Once you've made your changes, rebuilding with `make` and then using `make upload` should verify that everything went smoothly.
For the VESC Tool, installing Qt SDK is key. Just make sure you follow through with the additional packages like `mesa-common-dev` to avoid any graphical issues when building the project.
Stacy M.
NDIS Support Coordination
Relax
My family was planning a virtual game night to stay connected across provinces. Needed a platform that was reliable and had something for everyone. Checked out BettySpin Online from Canada, with a smooth design and tons of games. Their bonuses are cracking—welcome offers, reload deals, and loyalty perks. Slots, poker, and live dealers are all there, and payouts are hassle-free. Turned our night into a riot.
This is a great, detailed
This is a great, detailed guide! I remember struggling with the udev rules when I first set this up. It's easy to miss that step. For anyone taking a break from the coding, or waiting for something to compile, you might enjoy a quick game like Slope Game to clear your head. Thanks for putting this together, it will definitely help others.
Game
Hello, if the whole experience of interacting with the site is more important to you than just the game, https://luckyjet-in.com is worth a try. Indian users will have access to local recharge methods, tech support that understands the regional context, and a flexible bonus system that doesn't require complicated terms and conditions.
ragdoll playground
Ragdoll Playground is a sandbox game without any missions or objectives. It's simply pure inventiveness and unrestricted experimenting. Want to construct impregnable bases, aircraft, and submarines? Play Ragdoll Playground and explore without boundaries.
Setting up a development environment on Ubuntu 16.04 and later LTS releases is a great starting point for any developer. Clear guidance on installing essential tools like Git, VS Code, and language-specific packages (Python, Node.js, etc.) would be super helpful—especially for beginners aiming for a smooth setup process. By the way, if you need a quick break from coding, Basket Random Game is a fun and chaotic way to relax your mind! https://basketrandom.org
Hello. My name is Salman, and
Hello. My name is Salman, and I am from Pakistan. With years of hands-on expertise in lifestyle and fashion items, I specialise in offering professional insights into industry trends, as well as extensive information about skechers shoes price in Pakistan. My work is based on real-world industry expertise and aims to assist customers in making educated choices. I provide a realistic, on-the-ground view of the changing fashion and footwear scene.
Minecraft APK download for free
While full Java-style mods aren’t supported, you can install Add-Ons and texture packs from the Marketplace or import some third-party packs designed for the Bedrock version in Minecraft download apk.
Diving into the Fun of Store Management with Crazy Cattle 3D
This is a helpful guide! I remember struggling with the udev rules when I first set this up. One thing that helped me visualize the effect of these commands was thinking of it like building something, maybe because lately I play Crazy Cattle 3D and I'm used to build farms. Good instructions, though! Thanks for sharing.
To set up a development
To set up a development environment on Ubuntu 16.04 or later LTS releases, begin by updating your system and installing essential packages. Consider using tools like Docker for containerization. For a fun break, try Moto X3M to unwind! Ensure you configure your IDE, libraries, and dependencies according to your project's needs for optimal performance.
chicken jockey clicker
Thanks for the detailed guide! It reminds me of some simple games I used to play, like a chicken jockey clicker, just endlessly repeating a few steps to see progress. This looks a lot more useful though.
Spotify Mod APK
Ad-Free Experience: No interruptions from audio or banner ads while streaming music in Spotify Mod APK for free.
Great
Struggling with installing dependencies on Ubuntu? I used to! My workaround was using Docker containers, as they provide isolated environments and eliminate dependency conflicts. This approach saved me hours of troubleshooting! Has anyone else tried Docker for development setup?
Pacman 30th Anniversary
Has anyone else found setting up VESC development on Ubuntu tricky? I definitely struggled initially, mainly forgetting crucial dependencies. After a clean install and meticulous package management, though, it ran smoothly. Ah, memories of frustration and triumph… much like the satisfying chomping of Pacman 30th Anniversary
Thanks for the great guide!
Thanks for the great guide! It reminded me of the simple games I used to play—web experiences have come a long way.
If you're looking for reliable web development in Florida, there are top-tier services for custom software, marketplace platforms, API integrations, and enterprise solutions to help your business grow.
nice post
Great guide for setting up a VESC development environment on Ubuntu! The step-by-step instructions are clear and easy to follow. It's almost like navigating a level in Geometry Dash , each step precisely executed. I appreciate the inclusion of updating the system, installing necessary packages, and even building the firmware. Thanks for sharing this valuable resource!
Drift Hunters
This is a helpful guide! I remember struggling with the udev rules for the ST-Link V2 programmer. That part always seemed a bit obscure. I've used this setup for robotics projects and it worked great. For a fun break from coding, have you ever tried the online game Drift Hunters? It's surprisingly addictive!
Thanks for the helpful guide!
Thanks for the helpful guide! I remember struggling with setting up my dev environment for VESC a while back. Following a haphazard collection of forum posts left me pulling my hair out. This clear, concise approach is much better. For anyone getting frustrated with errors during installation, sometimes it's good to just take a five-minute break and play the Dinosaur Game in Chrome. It's surprisingly therapeutic!
Hello!
Just a couple of thoughts: First, it might be useful to mention the importance of ensuring that the system is fully updated before starting the installation process, as this can prevent compatibility issues down the line. Also, maybe consider adding a brief note about checking the version of Ubuntu they are using since some packages might differ slightly across versions.
When it comes to building the firmware, it’s great that you included how to change the hardware version in `conf_general.h`. Maybe you could also suggest some common pitfalls to watch out for during the compilation or uploading process, like ensuring that all necessary drivers are installed for the ST-Link v2 programmer.
Ann Hansen/CEO/Behaviour Services Consultant
<a href="https:/
<a href="https://cookieclicker.in/#">Cookie Clicker</a> on https://cookieclicker.in/# is super fun and addictive! I love clicking to make more cookies and unlocking upgrades and new buildings. The game is easy to play but hard to stop. Highly recommended for anyone looking for a relaxing game!
they all get hooked
I've shown stickman hook to so many friends, and they all get hooked (pun intended!). It's universally appealing, easy to understand, but difficult to put down. Great for short bursts of entertainment.
Lana電子煙主機怎麽控煙的?
在電子煙使用者逐漸重視吸煙體驗品質的趨勢下,"控煙" 功能成為評估一款電子煙主機的重要指標之一。作為市面上深受歡迎的產品之一,Lana皮革主機不僅外型時尚、手感出色,更搭載一系列先進控煙技術,提供穩定且舒適的霧化表現。本篇文章將深入介紹Lana皮革主機如何實現控煙功能,幫助用戶更有效掌握吸煙節奏與品質。
控煙核心一:氣流感應與智能霧化調節
Lanavape皮革主機的控煙機制,首先源於其氣流感應技術。當使用者開始吸氣時,內部氣壓感應器會即時啟動霧化程序,依據吸氣力度自動調節霧化器的輸出功率,實現煙霧量的智能控制。
這種設計不但提高了使用者的操控自由度,也避免因過度霧化而造成喉嚨刺激或耗油過快的問題。尤其對於剛接觸電子煙的新手,用戶可無需任何按鍵操作,即可獲得穩定的控煙體驗,這也是Lana主機深受喜愛的原因之一。
控煙核心二:穩定輸出與防過熱設計
為了進一步強化控煙的穩定性,Lanavape主機配備穩壓輸出系統,確保在電池電量變化過程中,輸出功率始終保持一致。這意味著無論電量高低,使用者都能獲得幾乎一致的煙霧量與口感,不會出現時強時弱的吸煙體驗。
此外,Lana電子煙主機內建過熱保護功能。當連續抽吸過快或主機溫度過高時,系統會自動限制輸出或短暫暫停,以避免過熱影響霧化品質與主機壽命。這項設計不僅延長主機使用時間,也進一步強化控煙的安全性。
控煙延伸:與煙彈結合的氣密設計
除了主機本身的智能系統外,Lana電子煙主機還強調與煙彈的氣密性結合。良好的氣密結構能減少氣流洩漏,使煙霧集中而順暢,有助於提升控煙效果與霧化效率。
當氣密性不足時,即便主機控制得再精準,也可能導致煙霧稀薄、味道不明顯。Lana電子菸主機與原廠煙彈完美匹配,能穩定輸出一致霧量,從而幫助使用者更精準地掌握每一口吸入量與口感強度。
總結:Lana皮革主機實現高效控煙的秘密
總的來說,LANA皮革主機能夠實現出色的控煙表現,關鍵在於其結合氣流感應、穩壓輸出、防過熱保護與氣密結構等多重設計。這些功能協同運作,讓使用者無論在吸力強弱或吸煙頻率上,都能獲得一致且穩定的霧化體驗。
對於追求高品質電子煙使用感的消費者來說,Lana皮革主機無疑是兼具智慧科技與貼心設計的理想選擇。若你正考慮升級主機,不妨親自體驗Lana皮革主機的控煙表現,讓每一次吸入都更輕鬆、舒適又安心。
Baseball bros io is an online
Baseball bros io is an online simulation game about baseball that has fun game features and fast-paced action. This game is fun and easy to play, no matter how much you know about sports or how much experience you have with video games.
betrupees apk
The Betrupees APK is the perfect solution for Indian players who want to gamble on the go. I love how fast and responsive the app is, even with multiple games running. The layout is clean and makes it easy to switch between slots, table games, and sports bets. Betrupees has made it easy to install their APK—just visit the official site and follow the steps. Everything from deposits to withdrawals works smoothly within the app. If you want the full Betrupees experience in your pocket, the Betrupees APK is a must-download for Android users.
IQOS ILUMA i PRIME:加熱煙體驗與暫停功能全解析
IQOS電子煙的使用感受獨具特色。由於其採用先進的加熱技術,菸草在不完全燃燒的情況下釋放尼古丁,IQOS ILUMA相比傳統香菸,減少了焦油和一氧化碳等有害物質的吸入。這讓吸菸者在享受菸草風味時,能顯著降低對健康的危害。
許多用戶回饋,日本電子煙能有效減輕咽喉刺激和咳嗽,且不會有日本煙那種濃烈刺鼻的煙味,加熱菸彈取而代之的是更溫和、清新的菸草香氣,抽吸過程順暢自然,口感醇厚且層次豐富。
IQOS ILUMA i PRIME 配備了實用的暫停功能,專為那些需要暫時中斷吸菸的用戶提供了一種便捷的解決方案。當您需要暫停吸菸時,只需輕輕一按暫停按鈕,設備即進入暫停模式,螢幕中間的四顆燈會同時亮起,直觀地表明設備已暫停加熱。
這一模式最長可維持 8 分鐘,橢圓形的燈會隨時間倒數逐漸減少,時刻提醒您剩餘暫停時間,確保您能及時恢復吸菸,避免菸草棒過度加熱或浪費。推薦閱讀:IQOS ILUMA機型介紹
IQOS ILUMA PRIME在暫停模式下,想要恢復吸菸非常簡單。只需在觸控螢幕開關由下而上輕掃一下,煙槍便會迅速重新加熱,您可以立即繼續正常使用。IQOS PRIME整個過程迅速且流暢,無需重新插入菸草棒或進行複雜操作,彷彿時間未曾中斷,讓您輕鬆延續吸菸體驗。
加熱煙暫停功能為吸菸者提供了更大的便利性和靈活性。無論是接聽電話、用餐還是短暫離座,暫停功能都能確保您的吸菸體驗不受干擾。不僅避免了不必要的菸草浪費,還延長了單根TEREA的使用壽命,使您能更經濟高效地享受菸草帶來的愉悅感。
We had an amazing day at axe
We had an amazing day at axe throwing in Libertyville. It brought the team together with top-notch team building and was one of the most fun corporate team building activities we’ve done. Love axe throwing now!
GACHA CUTE Download APK
The app is simple to navigate, with drag-and-drop features and clear menus for easy use GACHA CUTE.
sprunki phase
Thanks for the guide! I'm curious, has anyone experienced issues with the build process entering some kind of unexpected sprunki phase during compilation, and if so, what were the solutions?
SP2s 電子煙主機使用說明:簡單易懂,快速上手!
前言
對於電子煙的新用戶來說,瞭解如何正確使用和維護設備是非常重要的。SP2s電子煙主機憑藉其簡潔的設計和直觀的操作介面,讓新手也能夠輕鬆上手。
開箱與檢查
當您收到SP2s電子煙主機後,首先應該檢查包裝內的所有配件是否齊全無損,這通常包括主機、充電線以及可能的煙彈。確認所有物品完好無損後,可以開始閱讀隨附的說明書,熟悉各個部件的功能及基本操作步驟。
初次充電與啟動
為了確保最佳性能,建議在首次使用前對SP2s電子煙進行完全充電。使用原裝充電器連接電源,並根據指示燈顯示來確認充電狀態。當電量充滿後,您可以通過按下啟動按鈕來檢查設備是否正常運作,同時注意觀察燈光提示以瞭解電池電量情況。
安裝與更換煙彈
SP2s電子煙主機支持多種口味的煙彈,選擇適合自己口味的煙彈並將其正確插入主機。請確保煙彈安裝穩固,以避免漏油或蒸汽不足的情況發生。當需要更換煙彈時,只需輕鬆拔出舊煙彈,然後插入新的即可。
調節功率設置(如果適用)
部分SP2s型號提供了可調節的功率設置功能,允許用戶根據個人喜好調整吸食體驗。通過調整功率,您可以改變蒸汽量和溫度,從而影響口感。具體的調節方法可以參考產品說明書中的相關介紹。
日常維護與保養
定期清潔您的SP2s主機是保持其良好性能的重要環節。每次更換煙彈時,檢查並清理接口處的殘留物質;每隔一段時間還應對整個設備進行全面清潔。此外,遵循安全使用原則,如不在極端溫度下使用或存放設備。
結論
總結而言,SP2s電子煙主機以其簡潔明瞭的操作方式和人性化的設計,使得即使是電子煙的新手也能夠快速上手。小夥伴們別錯過!台灣SP2s官網線上店鋪提供正品Sp2s煙彈,多種口味任君選擇,現貨充足,快速發貨,讓您即刻享受新鮮口感。所有產品均通過嚴格檢驗,確保100%原裝正品!
After bouncing off a bunch of clickbait reviews, I landed on https://www.giveme5.co/group/discussions-about-episodes/discussion/6d725004-46b7-4673-b20d-89ae20b761ca where real users were having a conversation. One guy mentioned where he plays online and shared a legit link. I checked the options and saw solid features like cricket betting promos, fast KYC, and weekly offers. What made me trust it more is seeing several Indian users commenting their real experience.
Good
This creative scoring system will help me decide whether I can resume playing and raise on past performance. wave road
Escape Road
This is a great guide for setting up the development environment! It's really helpful to have all the steps laid out like this. If something goes wrong during the process, it's good to know there's an Escape Road with resources like this to help troubleshoot.
UNO Game
UNO has stood the test of time by staying true to its roots while continuing to evolve with new formats, rules, and digital platforms. It brings people together through friendly competition, unexpected twists, and shared laughter. Whether you're 6 or 60, new to card games or a seasoned player, uno online is guaranteed to offer excitement, connection, and unforgettable memories.
Your style of writing is refreshing and enjoyable. The way you present complex ideas in a simple and relatable manner makes your work very accessible play speed stars game. Keep up the great work—I’m definitely interested in reading more!
