Vesc 6 and encoder connections
eptv
Last seen: 6 months 4 days ago
I googled a lot about encoder connection to VESC.
I found that VESC 6 does not need modifications when connecting AS5047P encoder via software SPI bus to HALL port. And there is another way of connecting encoder to hardware spi port, but I have to to recompile firmware in this case.
How it works on schematic side that now is possible use HALL port for sensors and SPI without hardware modifications?
eptv
I found that AS5047P works over HALL port with Trampa 75/300 board without modifications. Also do not works with Maytech 60 board.
ergnmnh
hello sir , did you find anything about this issue , i also connect the encoder but The encoder I have is not standard, .How can I connect it to vesc6? I saw links to vesc4 on the internet, some resistors were being removed.But I'm not sure, the encoder I have has a total of 9 channels. of which 6 channels of axis, 1 axis vcc, 1 axis gnd and 1 axis shield. I don't know how to do this. Please help me with this issue because it seems like there is no other way for me to drive with POS.  here is the link of encoder's pinout : FNC 50H Connector Series (inelso.ru)
E.E.
