How to read COMM_ROTOR_POSITION through uart
Graham Bowen-Davies
I'm setting to up communication to teh VESC through an Arduino. Using SolidGeek's libraries, I have been able to send position control commands. What I need, is to read in the current position of the motor.
In order to set position, I modified the existing "setRPM" to make a "setPOS" command.
To set position, I naively tired to convert "getVescValues" to a "getVescPos", with the command value of "COMM_ROTOR_POSITION". But this does not seem to be recognized (payload size is zero).
Any pointers on how I should be going this are appreciated. I'm very new to arduino, and I have very little comfort with "C" language.
Graham Bowen-Davies
Nothing doing here? The following is the bit code that I attempted, but lenPayload returns zero
bool VescUart::getVescPos(void) {
	uint8_t command[1] = { COMM_ROTOR_POSITION };
	uint8_t payload[256];
	int lenSent = packSendPayload(command, 1);
	int lenPayload = receiveUartMessage(payload);
	Serial.println(lenPayload);
Graham
Gloobox
Hi Graham,
I have the same question than you ;), but do not have done some tests for now.
do you have solved your problem?
do you have tried to insert a delay between PackSend and UART reception?
Have a good day
Bruno
J_THAKKAR
Hi Graham,
I have same doubt when i send get_values it give me 79 bytes data but by sending comm_get_rotor pos vesc is not responding can youo please tell me what is the isuue or i can also find the rotor position from get values command.
mansi712
Anyone able to get this working?
I can get the live position of my motor out using PidPos with VescUart library, but dont know how to use it to run other vesc as this library doesnot support SetPosition().
mansi
