Command Line Options
Dude
Dude's picture
I want to use the VESC Tool to control a test motor on my dyno, e.g. to set up different rpm's in a sequence. This should be done automatically by calling the VESC Tool from another program. Are there any command line options available or does anybody know if I can use the capabilities of VESC Tool not by using the GUI but with some kind of script. Maybe there are other possibilities I don't know?
Last seen: 3 weeks 5 days ago
There is nothing like that available, but I could implement a page with a tcp or udp server that accepts xml commands similar to this:
https://github.com/vedderb/rise_sdvp/blob/master/Linux/RControlStation/n...
I will do some coding this weekend, so if this is useful I could add it.
Dude
Dude's picture
Would be great ... and maybe a very small example how to use it. Thanks!
Dude
Dude's picture
Hi Benjamin,
did you made any progress on that topic? Thx!
I was away all week and busy during the weekend, so not yet. Currently I'm working on implementing BLE support both in VESC Tool and on a nrf51822, but maybe I can make a release in between. I'm hoping to finish the ble support this weekend and publish source code for the nrf51822 for that, but I'm not sure if I will make it. Then I can start working on qml and making an official vesc tool app.
fredesc
I use a Maytech MTESC 6.0 and the android APP or OSX App, My ESC is tottally glued with a BLE (flipsky) module (efoil application). I made a mistake in a configuration and now I have all the time this message  'Could not read firmware version. Make sure that the selected port really belongs to the VESC'
Is there a possible solution with command line to force the update or reset the ESC ? Because it is fully flued I can't access to the USB port - only Bluetooth
Thanks for you answer
Fred
Fred ESC
woodmastr
hi all
i'd like to check on the progress of this request. is there as of now an option to access the vesc command set via a terminal ?
thanks
/J
