About How to control the "FLIPSKY Dual FSESC6.7 PLUS"
tonyH
Last seen: 1 year 2 weeks ago
Hello everyone,
Im Tony, I am studying how to control the motor speed according to throttle input values.
So, I found the "FLIPSKY Dual FSESC6.7 PLUS" and I already download Vesc Tool latest version.
But I have some problems..
Situation.
1. To operate an inner motor with 8 poles, a FLIPSKY DUAL FSESC6.7 PLUS motor driver (model name VC-67D-S100) was used.
2. The system was configured in sensorless mode, and VESC Tool was used as the motor drive control software.
3. For the test conditions, 12 V and 10 A were supplied to the motor driver in CV mode. A potentiometer was applied to adjust the load and control the motor speed.
Problem
- The RPM could not be controlled and the motor operated at a constant speed only.
- The motor would not start unless a certain minimum RPM command was applied.
- Adjusting the potentiometer did not affect the motor speed.
Also, I try to use the "FLIPSKY VX2 Receiver and remote" that also doesn't work...
According to the manual, I applied power to the driver, connected the receiver, and initiated pairing with the remote control. However, it did not operate. I confirmed that the blue LED on the receiver was blinking. Could you please tell me what might be the problem?
Thank you.
