Help Setup Flipsky FSESC 4.12
R66
Last seen: 1 year 2 weeks ago
Using the setup motors wizard went very straightforward.    Normal remote response. Like an idiot, after watching several videos, I did NOT realize the the flipsky VX1 remote is a UART connection and unfortunately , set up the ESC as a PPM ...
My question is how do I re configure / re program the ESC to accept the factory UART  VX1?
R66
Problem solved.  Farther down the menu on the Left hand side is  the General  app   .  Open that and select  UART , then write changes.
 Next select VESC Remote  App (2 items below General)  Open and configure as desired, then write changes.
Quick and easy.
