Vesc tool won't connect vesc to motor
moza1313
Last seen: 7 years 12 months ago
Please could someone give me an idea whati s going on.
FW:3.38 HW:410 (I have noticed that vesc says 4.12 on front of it however vesc tool says its 410, not sure if this is a problem)
It is a sk8 vesc with a KEDA 200kv BL motor
I has been working fine for the last month on the bench however now it wont connect to motor.
On FOC motor detect it takes about a minute or two for RL (the red led starts to flash 3 times every 10(ish) seconds) then says R=0, please measure first.
I have tried re-flashing firmware. I cant get the motor to do anything.
On RL detect it does vibrate and calculate L but says R=0
Fault : FAULT_CODE_DRV
Current : -0.2
Current filtered : -0.0
Voltage : 39.84
Duty : 0.012
RPM : 271.7
Tacho : 87
Cycles running : 2
TIM duty : 200
TIM val samp : 2
TIM current samp : 4200
TIM top : 16800
Comm step : 0
Temperature : 23.10
Current : -0.0
Voltage : 39.84
Duty : 0.015
RPM : 269.1
Tacho : 93
Cycles running : 2
TIM duty : 260
TIM val samp : 2
TIM top : 16800
Comm step : 0
Temperature : 23.00
shreeyak
That looks like the DRV chip might have been damaged. Try to replace the DRV chip and see if that helps?
Last seen: 10 months 6 days ago
410,411,412 are nearly identical and use the same Firmware.
Frank
