Vesc tool won't connect vesc to motor
moza1313
Please could someone give me an idea whati s going on.
FW:3.38 HW:410 (I have noticed that vesc says 4.12 on front of it however vesc tool says its 410, not sure if this is a problem)
It is a sk8 vesc with a KEDA 200kv BL motor
I has been working fine for the last month on the bench however now it wont connect to motor.
On FOC motor detect it takes about a minute or two for RL (the red led starts to flash 3 times every 10(ish) seconds) then says R=0, please measure first.
I have tried re-flashing firmware. I cant get the motor to do anything.
On RL detect it does vibrate and calculate L but says R=0
Fault : FAULT_CODE_DRV
Current : -0.2
Current filtered : -0.0
Voltage : 39.84
Duty : 0.012
RPM : 271.7
Tacho : 87
Cycles running : 2
TIM duty : 200
TIM val samp : 2
TIM current samp : 4200
TIM top : 16800
Comm step : 0
Temperature : 23.10
Current : -0.0
Voltage : 39.84
Duty : 0.015
RPM : 269.1
Tacho : 93
Cycles running : 2
TIM duty : 260
TIM val samp : 2
TIM top : 16800
Comm step : 0
Temperature : 23.00
shreeyak
That looks like the DRV chip might have been damaged. Try to replace the DRV chip and see if that helps?
410,411,412 are nearly identical and use the same Firmware.
Frank
