Vesc Express show up as "Serial ESP32" when connecting to USB.
rikard.wildare@...
Hi!
I've been using my Vesc express togheter with a Ennoid HV bms to do logging. Its been running for a couple of weeks but today I lost contact with it over wifi and BLE. Its connected to via CAN and when I connect the USB it shows up as Serial ESP32 \\.\COM15 in the VESC tool.
When I try to connect i get this message:
"Could not read firmware version. Make sure that the selected port really belongs to the VESC. If you are using UART, make sure that the port is enabled, connected correctly (rx to tx and tx to rx) and uses the correct baudrate"
Is it lost or can I do something to recover it?
BR
Rikard
miller12952
Last seen: 7 months 1 day ago
Hi.how did you solve this problem?
It gives the same error, but my receiver is burnt out.
zzSkateboards
Any luck with this error getting same message.  Won't connect.  Very frustratung
zzSkateboards
